After making a copy of the tables:
I used MySQLAdmin to convert each of the tables to InnoDB. It
displayed the correct "alter table table_name type=innobd;" box
before each change.
Before the changes, the three tables showed the same record
count. After the changes, they were wildly different. But, (with no
changes to the web pages) the application opens OK and I can call
up records. Did the conversion get rid of some records or what?
Also, one of the pages (that uses a lot of convoluted logic
for the display) takes a lot longer to appear than it used to. All
the other pages are open fine and display their forms, etc..
Updates seem a little slower, but not too bad.
Why is the record count different in the three tables? Why
might the one page be running slower? (Do I need to make any
changes in the original web page code?)
Prior to the conversion, the three MyISAM tables (*.MYD,
*.MYI, & *.frm) were all stored in the C:\\Program
Files\MySQL\MySQL Server 5.0\data\my_data directory. Now that
directory only holds ".frm" files. Where did the conversion put the
new tables?
I haven't yet tested the cftransactions to verify they work.
That's next.
Thanks.
