Show 3 replies
1. Re: Can't change the stroke size to be under 1pt
Mike Gondek2 Apr 7, 2014 2:12 PM (in response to socahweir)You are probably using the web profile for new documents, which has align to pixel grid on by default. Yout wnat that off, or else your stork wight swill need to be an number the tis 1 pixel or a multiple of.
If you are not working on web documents, change your new document profile.
You can turn off the feature here for the items selected,
2. Re: Can't change the stroke size to be under 1pt
socahweir Apr 7, 2014 2:18 PM (in response to Mike Gondek2)Wow, that is such an obvious miss on my part. Thank you! That's the problem.
3. Re: Can't change the stroke size to be under 1pt
Jacob Bugge Apr 7, 2014 2:23 PM (in response to socahweir)socahweir,
For the existing document, you may need to also untick Align New Objects to Pixel Grid in the options.
