I have several computers I need to install Adobe Presentor on, is their a way to install Presentor 9 silently. Let me be perfectly clear, NO USER INTERACTION, NO SCREENS, NO LOGINS. I have ran into to many companies that do not understand the true concept of SILENT INSTALLS.
Thank you,
Ralph A. Flickinger
ITS Special Project Manager
IMSA
Moving to Presenter forum.
Romit Sinha
Greetings from Adobe.
Yes you can perform silent installtion of Adobe Presenter 9 using CCP(Creative Cloud Packager). CCP will be available in your LWS website(www.licensing.adobe.com) . Download CCP from LWS website and create a package for Presenter 9.
Note: Make sure that the If you are using 64 bit OS then you have to create 64 bit package and if you are using 32 bit OS then you may need to create 32 bit package. Also this process is only applicable for 32 bit Powerpoint.
Please refer to the below link for more information of CCP:
http://helpx.adobe.com/creative-cloud/packager/creating-packages.html
After creating the package:
Steps to follow to deploy silently on single machine:
1. Open CMD in Administrator mode.
2. Give the path till inside the build folder of the package. For Example if the build is saved on your Desktop the path in CMD should be as below:
C:\Users\[username]\Desktop\Packagefolder\packagename\Build>
3. Now type the following installation command: msiexec.exe /i packagename.msi /quiet
4. Launch Task Manager.
5.There will be three process of “msiexec.exe”
a) 6.One will be under System
b) 7.Other Two will be under [username].
8.Installation will be completed once both the process of msiexec.exe under the [username] are finished.
9.The installation process with take 5 to 10 minutes
Mayank
