I've been developing on FlashBuilder4.6 (AIRSDK3.5) now.
I was among the build from compiled using ant.
Should be changed to 3.5 to 4.0 the AIRSDK me.
However, I will fail to compile in the method of until now.
I will fail in part of <mxmlc> of ant.
Will it need a new setting option?
Do I need additional settings such as the FLEX_HOME for AIRSDK?
Please tell me if you know.
I'm sorry .
I was wrong AIRSDK to use. (using the AIRSDK_Compiler.zip downloaded)
I was wrong FLEXSDK to use. (using the flex_sdk_4.6.zip downloaded)
It worked fine if you combine the correct FLEXSDK and AIRSDK.
FLEXSDK: using the "sdks/4.6.0" in FlashBuilder4.6
AIRSDK: using the AdobeAIRSDK.zip download
I'm sorry .
