0 Replies Latest reply: Apr 10, 2014 4:57 AM by AMCGracer RSS
    <Title> tag in Robohelp Topics single sourced from FrameMaker
    AMCGracer Community Member
      Hi all and hope everyone is well,
      I have a large user guide and help project with FrameMaker as the single source. The project is translated into 8 languages, To ensure consistent file names across all 8 languages in RH, I set the RH Topic Name setting to use my Filename marker in FrameMaker to name the HTM files. (Project Settings>Edit conversion settings for FrameMaker documents>Other Settings>Topic Name Settings>Topic Name Marker>Filename
      The problem is that this file name is also being used in the <title> tag within the HTML RH creates. The result is that when I run a search, the file name appears rather than the actual topic title.
      Oddly enough, I have a  handful of topic that are using the topic title in the <title> tag rather than the Filename. I cannot figure out why,  but because it does happen, I know that it can be done. See in my screen below, most of the topics use the same Title as the filename. However, two of the files use the topic title. The filename marker exists and is being used correctly for the filename. I want all of the topics to behave like "Approved invoices" and "Pending invoices"
      Can anyone help me force RH to use the topic title in the <Title> tag of the autogenerated HTML rather than the filename?
      Thank you so much for your help!
        --Amy
