1. Re: Problem Syncronizing Folder in V. 5.4 (and 5.3)
Jim Wilde Apr 11, 2014 9:51 AM (in response to sirlampsalot)The problem with the Folder synchronise process is that it is in two stages.....the first being a prima facie check for new files (2 in your case), the second being a more thorough check of the potential new files in accordance with your previous import options.....including the "Don't import suspected duplicates" option.
So, if that check-box is typically checked during import, AND if the two new files are in fact already in the catalog, then there will be zero files imported. You can check this by running the Synchronise again, make sure you have the Import dialog selected, when that opens uncheck the "Suspected Duplicates" check-box and see if those two files now appear.
That may be the problem, or it may be something related to the type of files that Lightroom doesn't like.
