I am creating courses in Adobe Presenter 9. Is it possible to remove the "Attachment" button from the Adobe Player when veiwing the course?
You can also modify the vconfig.xml file in the Presenter output files. There will be a value that is:
<uishow name="attachments" value="true"/>
Change it to:
<uishow name="attachments" value="false"/>
Hi There,
Greetings from Adobe.
If i understand correctly, in order to remove "Attachment" button you have to go Themes in Adobe Presenter and in Themes Editor under customize, select Full screen instead of Default in Display.
"Attachment" button will not appear in Full screen mode. If enable mode switching option in Themes Editor is checked then you can switch from Full screen to Default mode while previewing the course.
Ajit
Change it to:
This worked perfectly! Thanks Jorma!
