Locked
Unable to Register for installation of Admobe Flash 13.xxx
Guest
Apr 12, 2014 Apr 12, 2014
Adobe Flash Upgrade to 13.XXX will not complete. Error: unable to Register.
System XP. / SP3
IE 8
Tried reverting to previous version. Now have Flash 12.0.0.77 installed but that will not run. Does not show up in the "Manage Add Ons" section of IE.
932
Apr 20, 2014 Apr 20, 2014
I have exactly the same problem on the same OS/browser config. Clean Install didn't work.
I DO noticed files are left on the following folders after failed installation:
  • C:\Windows\system32
  • C:\Windows\system32\Macromed\Flash
  • %appdata%\Adobe\Flash Player
  • %appdata%\Macromedia\Flash Player
But delete these folders/files didn't solve the problem, either.
Is there a way to manually register Flash Player ActiveX?
Apr 21, 2014 Apr 21, 2014
Guest
Hello Vinix;
I've about given up on finding the solution. If you do get flash installed and working again please let me know what your solution is.
I even tried re-installing previous versions in a "clean install" and they will not work, no errors but no functionality. Like they are not being enabled. Good luck.
Jerry
Sent from my iPhone
Apr 22, 2014 Apr 22, 2014
The MSI installer didn't work for you?
Guest
Apr 23, 2014 Apr 23, 2014
Ok, I tried that MSI installer today and I was actually surprised that it
DID work.
Thanks..
(Would be nice to know what the actual problem was.)
It's a permission problem on your computer.  The MSI installer skips the extraction step that the EXE installer needs to go through.  Unfortunately I have no way of knowing what permissions are corrupted.
