Locked
Maximum concurrent vod and live connections
Apr 03, 2014 Apr 03, 2014
How to check maximum concurrent vod and live connections for a server could afford?
What factors will be depended?   For internal use, the NIC should be 1G port.
How I will know that the maximum capacity for the server had been reached?
685
Adobe Employee ,
Apr 07, 2014 Apr 07, 2014
Is it for HTTP streaming or for  rtmp(?) streaming.
What is the major difference between HTTP streaming and RTMP streaming?   What should be pros and cons for them?
If just firewall port opened for 80 on HTTP and 1935 on RTMP?   Any security issue between them?
On other hand, if there will be big difference between them when need to calculate on the maximum capacity?
I read from other articles that this should be also based on CPU, available memory, bitrate, resolutions, any formula?
Adobe Employee ,
Apr 11, 2014 Apr 11, 2014
In short, HTTP is stateless streaming while RTMP is connection oriented stateful streaming. I would suggest you read  etailed documentation available on web before you make any final decisions.
Apr 13, 2014 Apr 13, 2014
I have already read the white paper from http://www.adobe.com/content/dam/Adobe/en/products/ams/pdfs/ams5-intro-wp.pdf.
When to choose HDS are:
Examples of use cases for HTTP Dynamic Streaming include the following:
• Adaptive streaming behind restrictive firewalls
• Massive-scale live broadcasting
• Enhanced seeking over standard HTTP connections
• Enterprise streaming on existing network infrastructure
On other hand, as in-house deployment without firewall and also could allow port 1936 inside internal network.   So above benefits seem not significant.
So other than above reasons, how RTMP and HTTP will be differed in performance and others?
