Hi folks, does anyone know if there is a way to slow down the line particle speed in after effects?
I've already tried the Velocity and Gravity but these affect the shape and projectory of the particles, I'd like to just slow down the speed?
Pre-compose, time-remap/ Timewarp.
Mylenium
There are other particle systems that offer more control if you really need it. Expensive.
Build your main comp at a higher frame rate, render the movie, and bring it back into a 30fps comp. You can precompose and nest but the movie is generally easier to manage in your head. The highest frame rate I can use on my AE is 99fps. A more current version may offer higher frame rates.
