Test for null node in xml structure?
Guest
Jun 06, 2007 Jun 06, 2007
How do I test if a node in an xml document exists?
doing this returns an error if it doesn't exist.
x = myxmldoc["my-list"]["my-item] ["user-id"]["xmltext"];
"Element user-id is undefined in a Java object of type class coldfusion.xml.XmlNodeList."
Any help would be much appreciated..
Many thanks.! :)
Advanced techniques
1.7K
Advocate ,
Jun 07, 2007 Jun 07, 2007
Have you tried using isDefined() or StructKeyExists()?
Advocate ,
Oh, and I probably should mention - a VERY annoying habit of the adobe forum is to replace the text [ + i + ] with <i> (i.e. its the markup code that the adobe forum uses for italics). I'm guessing your above code is really:
x = myxmldoc["my-list"]["my-item][eye]["user-id"]["xmltext"];
and not some funky italic work.
Guest
Hi Michael,
Yes tried both of these it doesn't work unfortunately :(
Funny thing is, the error message on isdefined is:
user id is undefined in a Java object of type class coldfusion.xml.XmlNodeList.
Advocate ,
Jun 08, 2007 Jun 08, 2007
You could try getting around that using XMLSearch() + xPath. It should return an array (either empty or not) regardless of whether your element exists.
This is what I'd do.
Adam
There IS a missing double quote in that. I presume it's a typo.
You would certainly get a different error if that was in fact your code.
Adam
isDefined() will never work for this sort of thing: it can only deal with
simple variable names (letters, numbers, dots, underscores, currency
symbols, etc).
structKeyExists() DOES work though:
structKeyExists(myxmldoc["my-list"]["my-item"] , "user-id")
Adam
Guest
Jun 11, 2007 Jun 11, 2007
Thank you again Adam :)
structKeyExists(myxmldoc["my-list"]["my-item"], "user-id")
This worked..
Jun 12, 2007 Jun 12, 2007
I have a similar question. Here's my xml structure:
<Response>
<Service>
<Name>Overnight</Name>
<Charge>30</Charge>
</Service>
<Service>
<Name>TwoDay</Name>
<Charge>15</Charge>
</Service>
</Response>
How do I test whether the 'Overnight' service is available? I tried StructKeyExists(xmlObj["Response"]["Service"]["Name"],"Overnight") but it doesn't work.
Thanks.
Min
Guest
does it have multiple entries and needs an array element reference?
i.e if(StructKeyExists(xmlObj["Response"][index]["Service"]["Name"],"Overnight")){
//do something?
if not do a <cfdump var="#xmlobj#"> and post the result
StructKeyExists(xmlObj["Response"]["Service"]["Name"],"Overnight") returns false. The trouble is "Overnight" is not a key of the structure. In fact, when I do StructKeyList(xmlObj["Response"]["Service"]["Name"]), it returns me an empty list.
So how can I check whether "Overnight" exists as one of the service options?
Min
Guest
is your xmlobj a string or an actualy xml structure? have you done a cfdump to confirm, and parsed it with xmlparse or some other function?
Jun 13, 2007 Jun 13, 2007
Yes, I can confirm that xmlObj is an xml object. I used xmlParse to create it and checked it with cfdump.
Min
Ok, I think I figured out a way. I am not sure if this is the best and most efficient way, but it seems to work:
<cfset overnightSearch = xmlSearch(xmlObj, "Response/Service[Name ='Overnight']")>
to check that overnight service is available:
<cfif arrayLen(overnightSearch) gt 0>
to get the cost of overnight service:
xmlOvernight = xmlParse(overnightSearch)
cost = xmlOvernight["Charge"][1].xmlText
Sorry, slight correction.
To get the cost of overnight Service:
xmlOvernight = xmlParse(overnightSearch[1])
cost = xmlOvernight["Service"]["Charge"].xmlText
Advocate ,
You hit on the answer in an earlier post - "Overnight" is not a key for the structure - its the value of the key "Name". To test for it, you need to 1) verify that the element Name exists, and then 2) test to see if the value of the <name> element is "Overnight". Since "AND" in CF is a short circuit AND operator (operand? I never get my nominclature right), you can combine the tests into 1 CF statement:
<cfif structKeyExists(xmlObj["Response"]["Service"], "Name") AND xmlObj["Response"]["Service"]["Name"].xmlText eq "Overnight">
Do Something
</cfif>
Jun 14, 2007 Jun 14, 2007
The problem with <cfif xmlObj["Response"]["Service"]["Name"].xmlText eq "Overnight"> is it doesn't work for "TwoDay" since it is not the first child.
Min
Documentation
