What is script syntax for passing form to REST?
Apr 10, 2014 Apr 10, 2014
I'm lost. I am attempting to pass a FORMFIELD-parameter via the DELETE-method to a REST-function using script language.
I want to delete a resource. I get "Method not allowed", only "GET,OPTIONS,HEAD", so the DELETE-method is not understood.
I would apprechiate any meaningful input.
---------(service call)-------------
form.CategoryIDDelete = "X,Y,Z"
httpSvc = new http();
httpSvc.setMethod("DELETE");
httpSvc.setCharset("utf-8");
httpSvc.addParam(type="formfield", name="CategoryIDDelete", value="#FORM.CategoryIDDelete#");
httpSvc.setUrl("http://data.myDomain.net/rest/restService/categories");
res = httpSvc.send().getPrefix();
writeDump(res);
writeDump(FORM);
...calls the rest service function in the registred REST component.
Here I call CategoryIDDelete "catIDs".
---------(service function)---------
remote Array function delCategory(string catIDs restArgSource="FORM") httpMethod="DELETE" restpath="{catIDs}" produces="application/json" {
  var resp = [];
  if (len(catIDs) > 0) {
  return resp;
I am uncertain about many things; restArgSource="FORM", restPath="{catIDs}", and why DELETE is not an allowed method.
Advanced techniques
451
Apr 15, 2014 Apr 15, 2014
I thought you are on ColdFusion 11, which is still in Beta. However, I checked the http documentation and verified that all of your code is within existing syntax.
Why 'post' a form parameter when the method is 'delete'? To delete, I would just do something like
writeDump(res);
Message was edited by: BKBK
I have now had a good look at your code. It is unclear to me why your http is doing the delete. That is the REST service's job. So, you could just get the http service to do a Get, or Post, if you wish to pass a parameter:
httpSvc.setMethod("Get");
httpSvc.setMethod("Post");
writeDump(res);
Also, shouldn't there be a comma to separate the arguments catIDs and restArgSource?
The attribute restpath="{catIDs}" implies the respath will be evaluated from the value of catIDs. However, I do not understand why you need a form.
Documentation
