1. Re: x264 PRO & PROBE Plugin
Jeff Bellune Apr 15, 2014 3:37 AM (in response to coredvideo)It's an outstanding plug-in, and the author is very responsive to requests for help. However, it is expensive. But it's certainly worth it if you do a lot of H.264 encoding.
Cheers,
Jeff
2. Re: x264 PRO & PROBE Plugin
emiliano.tv Apr 15, 2014 5:47 AM (in response to coredvideo)hey there,
this is the first time ever that i answer in the adobe forums, and I've been here for awhile.
That's how much the plugin its worth,
if you're delivering to the web... Just get it, Also, as Jeff said, the support its great.
cheers
Emi
3. Re: x264 PRO & PROBE Plugin
coredvideo Apr 15, 2014 6:42 AM (in response to emiliano.tv)Thanks for heads up,
btw is it somehow save's time in long renders as u know "x264" takes alot time to render.
Regards
4. Re: x264 PRO & PROBE Plugin
emiliano.tv Apr 15, 2014 6:47 AM (in response to coredvideo)yes, you can... in the "encoding quality" box you can change between fast, medium, slow, very slow.
I tend to use "fast" for previewing. "Medium" and "slow" for long videos, and "very slow" for short clips. -
5. Re: x264 PRO & PROBE Plugin
JSS1138 Apr 15, 2014 7:49 AM (in response to coredvideo)I tried it once. It worked fine, but I found it lacking in the controls I wanted, so I let the trial expire and went back to the free x264 encoders, which offer the full range of x264 options.
6. Re: x264 PRO & PROBE Plugin
Jeff Bellune Apr 15, 2014 9:37 AM (in response to JSS1138)What controls do you need that it doesn't have? I bet if you put in a feature request with support at x264Pro you'd get some attention -- because if you need it then chances are someone else will too.
Cheers,
Jeff
7. Re: x264 PRO & PROBE Plugin
JSS1138 Apr 15, 2014 10:10 AM (in response to Jeff Bellune)Two that I recall are IP Ratio and PB Ratio. There may have been others.
But honestly, I think it should include them all. The free ones do.
8. Re: x264 PRO & PROBE Plugin
emiliano.tv Apr 15, 2014 10:21 AM (in response to JSS1138)Those sound like neat features... can you explain how do they work?
9. Re: x264 PRO & PROBE Plugin
In x264Pro you can set the I or P frame interval, as well as the GOP length.
"The free ones do" -- you mean the free x264 Premiere Pro plug-ins? I haven't been able to find any of those.
10. Re: x264 PRO & PROBE Plugin
JSS1138 Apr 15, 2014 4:16 PM (in response to Jeff Bellune)you can set the I or P frame interval
That's not quite what those parameters are for.
No, I mean the free x264 encoders. The ones that do have all the options and don't cost any money. (The fact that they require a DI is less of an issue than the missing parameters the the $300 price tag of x264Pro.)
