1. Re: "RoboHelp has stopped working" error
Peter Grainge Apr 9, 2014 12:24 AM (in response to sdryer)Given Rh will not open any project and the templates were missing, it looks rather like an installation issue. Did you install with admin rights?
If you did and if a second attempt fails, then I think the advice has to be the same as in the other thread, contact Adobe Support.
2. Re: "RoboHelp has stopped working" error
HelpDeskMSA Apr 14, 2014 9:07 AM (in response to Peter Grainge)Peter,
I have re-installed the application and am still getting that RoboHelp has stopped working. The curious thing about this is that the program runs fine under an administrator account. Once you use a user account that has administrator priveledges you have the problem. This is now an issue with 2 seperate installs getting the same error message. The faulting module is also a piece of Microsoft C++ Redistributable packages. Doesnt give the year or version in event viewer.
Edit: I have re-create the user profile, ran as administrator, re-installed the product and even tried running the save robohelp files from a directory where the user has full control.
3. Re: "RoboHelp has stopped working" error
Peter Grainge Apr 14, 2014 11:38 AM (in response to HelpDeskMSA)I wish I could help you but everything you are saying is telling me that this needs Adobe on the case.
It's an install error so the call should be free.
4. Re: "RoboHelp has stopped working" error
Peter Grainge Apr 15, 2014 2:06 AM (in response to Peter Grainge)I wonder if you would mind opening Rh HTML and opening a sample project to see if the same thing happens there. It might tell Adobe something and it might help me with another thread.
In Rh HTML, click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
Thanks.
5. Re: "RoboHelp has stopped working" error
HelpDeskMSA Apr 15, 2014 8:02 AM (in response to Peter Grainge)I have opened the project in Rh HTML and they open. Didnt try the sample one though.
6. Re: "RoboHelp has stopped working" error
sdryer Apr 15, 2014 8:49 AM (in response to Peter Grainge)Hi Peter,
I tried opening the Global Site Consult sample from the Starter window and at first it seemed like it wasn't opening. It did nothing for a while, so I tried opening a new blank project and then the Global Site Consult project opened on top of it. Now I can access the sample from the Starter window with no problem. - Sandy
7. Re: "RoboHelp has stopped working" error
Peter Grainge Apr 15, 2014 11:24 AM (in response to sdryer)Thanks for opening the Rh sample. You have confused me though as you say "the project" which sounds like your project but your project is a Rh for Word project.
In the root is there an hpj or an xpj or both?
8. Re: "RoboHelp has stopped working" error
HelpDeskMSA Apr 23, 2014 1:42 PM (in response to Peter Grainge)There is no .xpj file. Problem is that this software does not run under any account except administrator. I have found that installing word 2007 standalone resolves the bulk of the problems with opening the files. Now I just need to get this software running under user accounts that have admin privs.
9. Re: "RoboHelp has stopped working" error
Peter Grainge Apr 23, 2014 11:33 PM (in response to HelpDeskMSA)So you were trying to run Rh for Word without a copy of Word installed, correct?
It used to be the case that Word had to be installed before Rh. That is no longer true of Rh HTML but it may be true of Rh for Word. Try completely uninstalling RH using something like RevoUninstaller to completely clean up. It's free and lots of people have found it helps uninstall Rh.
Beyond that, sorry but as I have indicated, it's Adobe Support and it's free for installation issues.
