3 Replies Latest reply: Apr 17, 2014 12:22 AM by R_Sem RSS
    RH inserts filenames as title elements (instead of the actual chapter titles)
    R_Sem Community Member
      Hi all,
      I am not sure whether this is a bug or can be fixed. When I import from FM using chapter title paragraph styles for breaking the content into topics, then RH inserts the resulting file names into the topic as <title> elements and not the title names themselves.
      This is no problem as long as you can use the default naming convention (i.e. heading and filename identical). For some output formats hovever it is necessary to use a different naming convention to avoid non-english characters in file names. In such a case I use <n> as naming, resulting in files that have ascending numbers as file names.
      Now I receive e.g. a topic with the h1 heading "This is my topic", the filename "123.htm" and the HTML title "123". That is very bad because in the search results e.g. in Javahelp the HTML titles are displayed, resulting in unusable search results.
      Do you have any suggestions how to avoid this dilemma?
      Robert
