.net 4.5 support
Guest
May 31, 2013 May 31, 2013
Anyone know if the .net integration will get upgraded to support .net framework 4.5? Tried it out after upgrading to .net 4.5 and get the error "incorrect response header" thrown from com.jnbridge.jnbcore.JNBridgeInternalError.
2.3K
Jun 02, 2013 Jun 02, 2013
Hello, I am from the .NET Framework Compatibility Team. Could you contact us on netfx45compat at microsoft dot com with small project that reproduces this error.
Jul 18, 2013 Jul 18, 2013
I am from .NET Framework compatibility team. We would like to understand this better. Could you contact us on netfx45compat at microsoft dot com with sample app/project.
Varun Gupta
.NET Framework
Apr 17, 2014 Apr 17, 2014
I've tried updating to the latest version of .net (At this time 4.5.1) and there are still issues.  I've also noticed that the error seems to be occuring when a .net function returns a large string back to ColdFusion.
May 04, 2015 May 04, 2015
I realize this is an old thread, but I'm having the same issues and the last sentence appears to apply to my situation perfectly.  I'm doing some testing to see what kind of effort it'll be to upgrade to CF11.  This is a show stopper..
I've been unable to find even any other references to this issue after nearly 6 hours of searching.... Was there ANY kind of resolution to this issue at all?
Contributor ,
Aug 29, 2016 Aug 29, 2016
Fix for this issue can be taken here.  It would added in the upcoming update of ColdFusion 10.
http://blogs.coldfusion.com/assets/content/server/jnbridge-3864336.zip
Instructions are there in the same file.
Krishna
Contributor ,
Apr 21, 2017 Apr 21, 2017
Fix for this issue can be taken from here.
For ColdFusion 11 with .Net 4 - http://blogs.coldfusion.com/assets/content/server/jnbridge-3864336.Net4.zip
For ColdFusion 11 with .Net 2 - http://blogs.coldfusion.com/assets/content/server/jnbridge-3864336.Net2.zip
For ColdFusion 10 with .Net 4 - http://blogs.coldfusion.com/assets/content/server/cf10-jnbridge-3864336.Net2.zip
For ColdFusion 10 with .Net 2 - http://blogs.coldfusion.com/assets/content/server/cf10jnbridge-3864336.Net4.zip
Jul 17, 2013 Jul 17, 2013
I'm having the same/similar problem.  I downgraded to .net 4.0 and the problem went away.
Here's the error anyways, if it helps.  The assembly it was using was a pretty simple, homegrown dll that talks to MSMQ.
struct
Causeundefined
InnerException
struct
Causeundefined
LocalizedMessageincorrect response header
StackTrace
array
1
struct
ClassNamecom.jnbridge.jnbcore.c.b.a
FileNameundefined
LineNumber-1
MethodNamea
NativeMethodNO
2
struct
ClassNamecom.jnbridge.jnbcore.DotNetSideProxy
FileNameundefined
LineNumber-1
MethodNameint
NativeMethodNO
3
struct
FileNameundefined
LineNumber-1
MethodNameobjectVirtualCall
NativeMethodNO
4
struct
ClassNameSpiralMsg.SpiralMsg
FileName[empty string]
LineNumber-1
MethodNamemsgToString
NativeMethodNO
5
struct
ClassNamesun.reflect.NativeMethodAccessorImpl
FileNameNativeMethodAccessorImpl.java
LineNumber-2
MethodNameinvoke0
NativeMethodYES
6
struct
LineNumber57
MethodNameinvoke
NativeMethodNO
7
struct
ClassNamesun.reflect.DelegatingMethodAccessorImpl
FileNameDelegatingMethodAccessorImpl.java
LineNumber43
MethodNameinvoke
NativeMethodNO
8
struct
ClassNamejava.lang.reflect.Method
FileNameMethod.java
LineNumber601
MethodNameinvoke
NativeMethodNO
9
struct
ClassNamecoldfusion.runtime.java.JavaProxy
FileNameJavaProxy.java
LineNumber97
MethodNameinvoke
NativeMethodNO
10
struct
ClassNamecoldfusion.runtime.dotnet.DotNetProxy
FileNameDotNetProxy.java
LineNumber38
MethodNameinvoke
NativeMethodNO
11
struct
ClassNamecoldfusion.runtime.CfJspPage
FileNameCfJspPage.java
LineNumber2432
MethodName_invoke
NativeMethodNO
12
struct
ClassNamecfxml2ecfc1581484751$funcSENDXML
FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\modules\singletons\xml.cfc
LineNumber1438
MethodNamerunFunction
NativeMethodNO
13
struct
ClassNamecoldfusion.runtime.UDFMethod
FileNameUDFMethod.java
LineNumber472
MethodNameinvoke
NativeMethodNO
14
struct
ClassNamecoldfusion.filter.SilentFilter
FileNameSilentFilter.java
LineNumber47
MethodNameinvoke
NativeMethodNO
15
struct
ClassNamecoldfusion.runtime.UDFMethod$ReturnTypeFilter
LineNumber405
MethodNameinvoke
NativeMethodNO
16
struct
ClassNamecoldfusion.runtime.UDFMethod$ArgumentCollectionFilter
LineNumber368
MethodNameinvoke
NativeMethodNO
17
struct
ClassNamecoldfusion.filter.FunctionAccessFilter
FileNameFunctionAccessFilter.java
LineNumber55
MethodNameinvoke
NativeMethodNO
18
struct
LineNumber321
MethodNamerunFilterChain
NativeMethodNO
19
struct
LineNumber220
MethodNameinvoke
NativeMethodNO
20
struct
LineNumber2659
MethodName_invokeUDF
NativeMethodNO
21
struct
ClassNamecfxml2ecfc1581484751$funcGETALLORDERHISTORY
LineNumber573
NativeMethodNO
22
struct
LineNumber472
MethodNameinvoke
NativeMethodNO
23
struct
LineNumber47
MethodNameinvoke
NativeMethodNO
24
struct
LineNumber405
MethodNameinvoke
NativeMethodNO
25
struct
LineNumber368
MethodNameinvoke
NativeMethodNO
26
struct
LineNumber55
MethodNameinvoke
NativeMethodNO
27
struct
LineNumber321
NativeMethodNO
28
struct
LineNumber220
MethodNameinvoke
NativeMethodNO
29
struct
ClassNamecoldfusion.runtime.TemplateProxy
FileNameTemplateProxy.java
LineNumber655
MethodNameinvoke
NativeMethodNO
30
struct
LineNumber444
MethodNameinvoke
NativeMethodNO
31
struct
LineNumber414
MethodNameinvoke
NativeMethodNO
32
struct
LineNumber2432
MethodName_invoke
NativeMethodNO
33
struct
ClassNamecforderHistory2ecfm2140766359
FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\orderHistory.cfm
LineNumber118
MethodName_factor12
NativeMethodNO
34
struct
LineNumber1
MethodNamerunPage
NativeMethodNO
35
struct
LineNumber244
MethodNameinvoke
NativeMethodNO
36
struct
ClassNamecoldfusion.tagext.lang.IncludeTag
FileNameIncludeTag.java
LineNumber444
MethodNamedoStartTag
NativeMethodNO
37
struct
LineNumber2799
MethodName_emptyTcfTag
NativeMethodNO
38
struct
ClassNamecfthemer2ecfm992586638
FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\includes\themer.cfm
LineNumber314
MethodName_factor7
NativeMethodNO
39
struct
LineNumber167
MethodName_factor48
NativeMethodNO
40
struct
LineNumber1
MethodNamerunPage
NativeMethodNO
41
struct
LineNumber244
MethodNameinvoke
NativeMethodNO
42
struct
LineNumber444
NativeMethodNO
43
struct
LineNumber2799
NativeMethodNO
44
struct
ClassNamecfapplication2ecfc1132292741$funcONREQUEST
FileNameM:\Spiral Binding Company\spiralbinding.com\dev10\application.cfc
LineNumber67
NativeMethodNO
45
struct
LineNumber472
MethodNameinvoke
NativeMethodNO
46
struct
LineNumber368
MethodNameinvoke
NativeMethodNO
47
struct
LineNumber55
MethodNameinvoke
NativeMethodNO
48
struct
LineNumber321
NativeMethodNO
49
struct
LineNumber220
MethodNameinvoke
NativeMethodNO
50
struct
LineNumber655
MethodNameinvoke
NativeMethodNO
51
struct
LineNumber444
MethodNameinvoke
NativeMethodNO
52
struct
LineNumber414
MethodNameinvoke
NativeMethodNO
53
struct
ClassNamecoldfusion.runtime.AppEventInvoker
FileNameAppEventInvoker.java
LineNumber108
MethodNameinvoke
NativeMethodNO
54
struct
LineNumber300
MethodNameonRequest
NativeMethodNO
55
struct
ClassNamecoldfusion.filter.ApplicationFilter
FileNameApplicationFilter.java
LineNumber424
MethodNameinvoke
NativeMethodNO
56
struct
ClassNamecoldfusion.filter.RequestMonitorFilter
FileNameRequestMonitorFilter.java
LineNumber48
MethodNameinvoke
NativeMethodNO
57
struct
ClassNamecoldfusion.filter.MonitoringFilter
FileNameMonitoringFilter.java
LineNumber40
MethodNameinvoke
NativeMethodNO
58
struct
ClassNamecoldfusion.filter.PathFilter
FileNamePathFilter.java
LineNumber112
MethodNameinvoke
NativeMethodNO
59
struct
ClassNamecoldfusion.filter.LicenseFilter
FileNameLicenseFilter.java
LineNumber30
MethodNameinvoke
NativeMethodNO
60
struct
ClassNamecoldfusion.filter.ExceptionFilter
FileNameExceptionFilter.java
LineNumber94
MethodNameinvoke
NativeMethodNO
61
struct
ClassNamecoldfusion.filter.ClientScopePersistenceFilter
FileNameClientScopePersistenceFilter.java
LineNumber28
MethodNameinvoke
NativeMethodNO
62
struct
ClassNamecoldfusion.filter.BrowserFilter
FileNameBrowserFilter.java
LineNumber38
MethodNameinvoke
NativeMethodNO
63
struct
ClassNamecoldfusion.filter.NoCacheFilter
FileNameNoCacheFilter.java
LineNumber46
MethodNameinvoke
NativeMethodNO
64
struct
ClassNamecoldfusion.filter.GlobalsFilter
FileNameGlobalsFilter.java
LineNumber38
MethodNameinvoke
NativeMethodNO
65
struct
ClassNamecoldfusion.filter.DatasourceFilter
FileNameDatasourceFilter.java
LineNumber22
MethodNameinvoke
NativeMethodNO
66
struct
ClassNamecoldfusion.filter.CachingFilter
FileNameCachingFilter.java
LineNumber62
MethodNameinvoke
NativeMethodNO
67
struct
ClassNamecoldfusion.CfmServlet
FileNameCfmServlet.java
LineNumber219
MethodNameservice
NativeMethodNO
68
struct
ClassNamecoldfusion.bootstrap.BootstrapServlet
FileNameBootstrapServlet.java
LineNumber89
MethodNameservice
NativeMethodNO
69
struct
ClassNameorg.apache.catalina.core.ApplicationFilterChain
FileNameApplicationFilterChain.java
LineNumber305
MethodNameinternalDoFilter
NativeMethodNO
70
struct
LineNumber210
MethodNamedoFilter
NativeMethodNO
71
struct
ClassNamecoldfusion.monitor.event.MonitoringServletFilter
FileNameMonitoringServletFilter.java
LineNumber42
MethodNamedoFilter
NativeMethodNO
72
struct
ClassNamecoldfusion.bootstrap.BootstrapFilter
FileNameBootstrapFilter.java
LineNumber46
MethodNamedoFilter
NativeMethodNO
73
struct
LineNumber243
NativeMethodNO
74
struct
LineNumber210
MethodNamedoFilter
NativeMethodNO
75
struct
ClassNameorg.apache.catalina.core.StandardWrapperValve
FileNameStandardWrapperValve.java
LineNumber224
MethodNameinvoke
NativeMethodNO
76
struct
ClassNameorg.apache.catalina.core.StandardContextValve
FileNameStandardContextValve.java
LineNumber169
MethodNameinvoke
NativeMethodNO
77
struct
ClassNameorg.apache.catalina.authenticator.AuthenticatorBase
FileNameAuthenticatorBase.java
LineNumber472
MethodNameinvoke
NativeMethodNO
78
struct
ClassNameorg.apache.catalina.core.StandardHostValve
FileNameStandardHostValve.java
LineNumber168
MethodNameinvoke
NativeMethodNO
79
struct
ClassNameorg.apache.catalina.valves.ErrorReportValve
FileNameErrorReportValve.java
LineNumber98
MethodNameinvoke
NativeMethodNO
80
struct
ClassNameorg.apache.catalina.valves.AccessLogValve
FileNameAccessLogValve.java
LineNumber928
MethodNameinvoke
NativeMethodNO
81
struct
ClassNameorg.apache.catalina.core.StandardEngineValve
FileNameStandardEngineValve.java
LineNumber118
MethodNameinvoke
NativeMethodNO
82
struct
ClassNameorg.apache.catalina.connector.CoyoteAdapter
FileNameCoyoteAdapter.java
LineNumber414
MethodNameservice
NativeMethodNO
83
struct
ClassNameorg.apache.coyote.ajp.AjpProcessor
FileNameAjpProcessor.java
LineNumber204
MethodNameprocess
NativeMethodNO
84
struct
ClassNameorg.apache.coyote.AbstractProtocol$AbstractConnectionHandler
FileNameAbstractProtocol.java
LineNumber539
MethodNameprocess
NativeMethodNO
85
struct
ClassNameorg.apache.tomcat.util.net.JIoEndpoint$SocketProcessor
FileNameJIoEndpoint.java
LineNumber298
MethodNamerun
NativeMethodNO
86
struct
ClassNamejava.util.concurrent.ThreadPoolExecutor
FileNameThreadPoolExecutor.java
LineNumber1145
MethodNamerunWorker
NativeMethodNO
87
struct
ClassNamejava.util.concurrent.ThreadPoolExecutor$Worker
LineNumber615
MethodNamerun
NativeMethodNO
88
struct
ClassNamejava.lang.Thread
FileNameThread.java
LineNumber722
MethodNamerun
NativeMethodNO
Suppressed
array [empty]
aundefined
LocalizedMessageundefined
Messageundefined
StackTrace
array
1
struct
LineNumber-1
NativeMethodNO
2
struct
LineNumber-2
MethodNameinvoke0
NativeMethodYES
3
struct
LineNumber57
MethodNameinvoke
NativeMethodNO
4
struct
LineNumber43
MethodNameinvoke
NativeMethodNO
5
struct
FileNameMethod.java
LineNumber601
MethodNameinvoke
NativeMethodNO
6
struct
LineNumber97
MethodNameinvoke
NativeMethodNO
7
struct
LineNumber38
MethodNameinvoke
NativeMethodNO
8
struct
LineNumber2432
MethodName_invoke
NativeMethodNO
9
struct
LineNumber1438
NativeMethodNO
10
struct
LineNumber472
MethodNameinvoke
NativeMethodNO
11
struct
LineNumber47
MethodNameinvoke
NativeMethodNO
12
struct
LineNumber405
MethodNameinvoke
NativeMethodNO
13
struct
LineNumber368
MethodNameinvoke
NativeMethodNO
14
struct
LineNumber55
MethodNameinvoke
NativeMethodNO
15
struct
LineNumber321
NativeMethodNO
16
struct
LineNumber220
MethodNameinvoke
NativeMethodNO
17
struct
LineNumber2659
NativeMethodNO
18
struct
LineNumber573
NativeMethodNO
19
struct
LineNumber472
MethodNameinvoke
NativeMethodNO
20
struct
LineNumber47
MethodNameinvoke
NativeMethodNO
21
struct
LineNumber405
MethodNameinvoke
NativeMethodNO
22
struct
LineNumber368
MethodNameinvoke
NativeMethodNO
23
struct
LineNumber55
MethodNameinvoke
NativeMethodNO
24
struct
LineNumber321
NativeMethodNO
25
struct
LineNumber220
MethodNameinvoke
NativeMethodNO
26
struct
LineNumber655
MethodNameinvoke
NativeMethodNO
27
struct
LineNumber444
MethodNameinvoke
NativeMethodNO
28
struct
LineNumber414
MethodNameinvoke
NativeMethodNO
29
struct
LineNumber2432
MethodName_invoke
NativeMethodNO
30
struct
LineNumber118
MethodName_factor12
NativeMethodNO
31
struct
LineNumber1
MethodNamerunPage
NativeMethodNO
32
struct
LineNumber244
MethodNameinvoke
NativeMethodNO
33
struct
LineNumber444
NativeMethodNO
34
struct
LineNumber2799
NativeMethodNO
35
struct
LineNumber314
MethodName_factor7
NativeMethodNO
36
struct
LineNumber167
MethodName_factor48
NativeMethodNO
37
struct
LineNumber1
MethodNamerunPage
NativeMethodNO
38
struct
LineNumber244
MethodNameinvoke
NativeMethodNO
39
struct
LineNumber444
NativeMethodNO
40
struct
LineNumber2799
NativeMethodNO
41
struct
LineNumber67
NativeMethodNO
42
struct
LineNumber472
MethodNameinvoke
NativeMethodNO
43
struct
LineNumber368
MethodNameinvoke
NativeMethodNO
44
struct
LineNumber55
MethodNameinvoke
NativeMethodNO
45
struct
LineNumber321
NativeMethodNO
46
struct
LineNumber220
MethodNameinvoke
NativeMethodNO
47
struct
LineNumber655
MethodNameinvoke
NativeMethodNO
48
struct
LineNumber444
MethodNameinvoke
NativeMethodNO
49
struct
LineNumber414
MethodNameinvoke
NativeMethodNO
50
struct
LineNumber108
MethodNameinvoke
NativeMethodNO
51
struct
LineNumber300
MethodNameonRequest
NativeMethodNO
52
struct
LineNumber424
MethodNameinvoke
NativeMethodNO
53
struct
LineNumber48
MethodNameinvoke
NativeMethodNO
54
struct
LineNumber40
MethodNameinvoke
NativeMethodNO
55
struct
LineNumber112
MethodNameinvoke
NativeMethodNO
56
struct
LineNumber30
MethodNameinvoke
NativeMethodNO
57
struct
LineNumber94
MethodNameinvoke
NativeMethodNO
58
struct
LineNumber28
MethodNameinvoke
NativeMethodNO
59
struct
LineNumber38
MethodNameinvoke
NativeMethodNO
60
struct
LineNumber46
MethodNameinvoke
NativeMethodNO
61
struct
LineNumber38
MethodNameinvoke
NativeMethodNO
62
struct
LineNumber22
MethodNameinvoke
NativeMethodNO
63
struct
LineNumber62
MethodNameinvoke
NativeMethodNO
64
struct
LineNumber219
MethodNameservice
NativeMethodNO
65
struct
LineNumber89
MethodNameservice
NativeMethodNO
66
struct
LineNumber305
NativeMethodNO
67
struct
LineNumber210
MethodNamedoFilter
NativeMethodNO
68
struct
LineNumber42
MethodNamedoFilter
NativeMethodNO
69
struct
LineNumber46
MethodNamedoFilter
NativeMethodNO
70
struct
LineNumber243
NativeMethodNO
71
struct
LineNumber210
MethodNamedoFilter
NativeMethodNO
72
struct
LineNumber224
MethodNameinvoke
NativeMethodNO
73
struct
LineNumber169
MethodNameinvoke
NativeMethodNO
74
struct
LineNumber472
MethodNameinvoke
NativeMethodNO
75
struct
LineNumber168
MethodNameinvoke
NativeMethodNO
76
struct
LineNumber98
MethodNameinvoke
NativeMethodNO
77
struct
LineNumber928
MethodNameinvoke
NativeMethodNO
78
struct
LineNumber118
MethodNameinvoke
NativeMethodNO
79
struct
LineNumber414
MethodNameservice
NativeMethodNO
80
struct
LineNumber204
MethodNameprocess
NativeMethodNO
81
struct
LineNumber539
MethodNameprocess
NativeMethodNO
82
struct
LineNumber298
MethodNamerun
NativeMethodNO
83
struct
LineNumber1145
MethodNamerunWorker
NativeMethodNO
84
struct
LineNumber615
MethodNamerun
NativeMethodNO
85
struct
FileNameThread.java
LineNumber722
MethodNamerun
NativeMethodNO
Suppressed
array [empty]
Documentation
