1. Re: Re-linking media by name and duration
JSS1138 Apr 17, 2014 3:28 PM (in response to BISLY)At this time, Duration is not one of the parameters you can match automatically.
2. Re: Re-linking media by name and duration
BISLY Apr 17, 2014 3:45 PM (in response to JSS1138)Hi jim,
Whats the hold up?
As known AVCHD recording is quite common, and almost every project i'v worked on has arroused this kind of issue.
Maybe it a feature to think about for the next version of premiere...
In my case, im working on a consolidate project of the main one, which addded automatically to all of the similar files an extension of 001, 002 and so on.
so when im linking the media, even the name is not the same and the duration is really my only indication. as there is a "match exact name" feature, maybe there could be "match exact duration" which you can turn on\off seperately.It will help a lot. -
3. Re: Re-linking media by name and duration
shooternz Apr 17, 2014 4:15 PM (in response to BISLY)Could be a workflow and project management issue.
I work with AVCHD files from multiple source folders and multiple "rushes" bins in Premiere (and never have a relinking issue.)
Wondering how yours gets "confused".
Do you have a Project management "strategy"?
4. Re: Re-linking media by name and duration
JSS1138 Apr 18, 2014 5:33 PM (in response to BISLY)Whats the hold up?
No idea, man. I'm just a user like you. I've no special knowledge about what goes on behind the scenes at Adobe.
Having said that, I would say that Adobe has pretty much solved this issue without needing a Duration parameter. Using Link and Locate, we can now see exactly where the file used to be, which is a HUGE clue as to which file is being asked for.
