I cannot install the pluggin. This message appears: Connection lost....It blocks at 7%
when i try to install this, it says that this is not a valid Win32 application.... what does it mean?
"not a valid Win32 application"
Means your anti-virus has blocked a part of the download and it's incomplete, even though ti appears to have fully downloaded.
Disable the A/V and THEN right click one or both of the first two links Ilisted, and "Save" them to your downloads folder.
Close your browser, and then run the installer.
I have done what you told me, but the same message appears. Maybe the application is made for a 64-bit computer...
No... It's a 32/64 bit installer. It installs 43 bit always and 64 as well if the system is 64 bit.
The error you're seeing only comes from a broken download.
Try using the MSI installer: http://download.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_13_active_...
Right click it. "Save target as", close the browser and run it.
Any idea?
Still a broken download.
If you have Windows Firewall on, turn it off.
Still the same message.
Nothing more can be done.
If you have a thumb drive, try downloading at another location on another computewr, and then run the installer from the thumb drive on this one. But whatever you have on this is preventing it from downloading completely, and we can't fix that from here.
