Triggering and Stopping a Stored Procedure
Guest
Jun 12, 2007 Jun 12, 2007
I'm setting up a mass mailing system for approx 250,000 users.
I need to find a way to trigger a stored procedure to run every 5 miuntes untill the task is complete. The idea being that once triggered it'll work its merry way through the database firing off a couple of thousand emails each cycle untill it's reached the end.
Any ideas how to implement this?
Advanced techniques
261
Advocate ,
Generally, the term "stored procedure" is used to mean a piece of SQL code that is stored and run in the database server. It sounds like what you mean is a ColdFusion Scheduled Task - a piece of CF code that is run automatically. You can set these up using either the CF administrator or the <cfschedule> tag. Breaking up your mailings is a good idea since CF will probably time out if you try to execute 250,000 mailings at once. You could do something like this:
1) If unsent records, do:
2) Select X number of unsent records
3) Send mail
4) Update X records as having been sent
You would just have to make sure that you time it correctly, otherwise you could wind up with 1 process starting before the other finishes and some people will get duplicate emails.
Guest
Jun 13, 2007 Jun 13, 2007
The email content is provided using a form in the sites CMS - at the moment I have the submit button going to a page that runs the cycle, sends the email to 2,000 users, marks it as sent in the database and then waits 5 minutes before reloading that page and starting from the next record.
How do I implement that with cfshedule? I've never needed to use it before so I'm totally in the dark.
Advocate ,
Take a look at the Adobe docs on cfschedule. I believe there is an example there that might shed some light:
http://livedocs.adobe.com/coldfusion/6.1/htmldocs/tags-a30.htm
Documentation
