Im trying to figure out how to approch a problem. what I want to do is generate a new file/link, maybe using 'cffile' or any other way.
Right now i have cse_newsletter.cfm , that looks like this(kind of)
<html>
<cfquery>
select ....
</cfquery>
select ....
<cfquery>
</cfquery>
<cfoutput>
<h1>Starburst Star Award</h1>
<h3>Winner: Department- #highest_dept_name_average#</h3>
<h3>Average: #hihest_dept_average# </h3>
<h4>Runner-up: Department- #highest_dept_name_runnerup# </h4>
<h4> Average: #highest_dept_name_average_runnerup# </h4>
</cfoutput>
</html>
the query works and give me the correct output i want.(rigth now i use cfshedule to run it, but everytime i will run it will overwrite the old data with the new) what it does it gives me the data of the past month.
so every tiime it runs it should give me the data from the past month.
I would like to make it that everytime i click on a submit(maybe there is a better way to do it without submit) it will give me a static txt/link that has the data.
i know that with cffile="write" it can give me a txt file(and this file can be overwritten) , but i would preffer if is easier to just me a link on cse_newsletter.cfm that will output/display what is on the body right now in cse_newsletter.
please give me any advice/suggestion, maybe a article i can read online (havent found anything that can help me)
this right her is the cfshedule, right now is on update, so obvioulsy it wont work with update, but i dont think with what i want i can accomplish with cffile "write"
<cfschedule action = "update"
task = "TaskName"
operation = "HTTPRequest"
url = "cse_execoffice_newsletter.cfm"
startDate = "04/18/14"
startTime = "11:19 AM"
interval = "3600"
resolveURL = "Yes"
thanks
I mean that your cse_newsletter.cfm template can be designed to accept parameters to show a newsletter for a certain month and year. If it accepts URL parameters then you can create a link to it like this:
http://mydomain.com/cse_newsletter.cfm?month=1&year=2014
And, if parameters are not passed, you could make it show the user a list of months and years (via form controls e.g. selection list) so that they can select the month and year that they require. That's how I would design it anyway. Unless
...Copy link to clipboard
You could show a bit more respect to the forum. You are fast giving me the impression you want to come here with a list of requirements and have fellow developers do your work for you.
I have given suggestions in a number of your threads. There was always silence whenever it reached the point where you needed to give more information. Here are recent examples:
http://forums.adobe.com/message/6303098#6303098
http://forums.adobe.com/message/6303093#6303093
http://forums.adobe.com/message/6299165#6299165
http://forums.adobe.com/message/6295752#6295752
http://forums.adobe.com/message/6292024#6292024
http://forums.adobe.com/message/6288569#6288569
You don't even have to thank colleagues. However, you owe it to the forum to simply acknowledge whether or not a suggestion has helped.
@no_name_123:
"please give me any advice/suggestion, maybe a article i can read online (havent found anything that can help me)"
Change your approach to the problem. First of all make your script create the data you require and then write it into a database for the appropriate month/year. Then you can just make cse_newsletter.cfm ask the user for a date/month/year and then generate the report (defaulting it to the current month/year perhaps.) That way, the end-user can request a newsletter for any valid month/year that exists in the database. If you want, you can also make the script accept URL parameters e.g. cse_newsletter.cfm?month=1&year=2014 and serve up the newsletter that way too. It will be a nice little project, good luck.
what do you mean by
"can just make cse_newsletter.cfm ask the user for a date/month/year"?
And, if parameters are not passed, you could make it show the user a list of months and years (via form controls e.g. selection list) so that they can select the month and year that they require. That's how I would design it anyway. Unless your data is stored somewhere in a database, your template will only ever work for one scenario (the last month), and that is a big limitation since people cannot then see past newsletters. You may not need to write files to disk etc, since the template just needs to show the correct newsletter. You can create whatever link to the newsletter you require once it has been designed to accept month and year parameters (which are in turn fed to your CFQUERY tags to get the data).
thank you i been thinking about this the wrong way, now i know how i should do it and go about it
There are many ways to tackle this, so I am not sure I gave you the correct answer, rather an answer. Good luck with it anyway.
well your answer help me find out how i should do it, after i read your comment i did some research and figure out how to approch the problem , so thanks
