1. Re: Prelude Crashing on "Ingest" Win7. 64
michaelgoshey Apr 19, 2014 5:56 PM (in response to JohnnyMilk)Hi Johnny,
One of our lead Prelude QE will reach out to you. They may want to peek at your folder structure and system settings to help better understand the environment you are in.
The only known issue with crashing on ingest is related to the missing folders which the installer was failing to create. This is fixed in our upcoming release. You do mention that you are aware of this issue and it didn't fix your problem. We will work with you to identify the core issue and resolve it.
Michael
2. Re: Prelude Crashing on "Ingest" Win7. 64
JohnnyMilk Apr 19, 2014 6:46 PM (in response to michaelgoshey)Thank you for responding.
3. Re: Prelude Crashing on "Ingest" Win7. 64
Ada_Wang Apr 20, 2014 8:46 PM (in response to JohnnyMilk)Hi Johnny,
Could you please try below steps for me and let me know the result?
1. Please go to Your Disk:\Users\Public\Public Documents\, clear(or rename to 'Adobe1" if you want to backup the existed folders) the folders under "Public Documents"
2. Re-launch Prelude to let Prelude re-creates the folders
3. Try the "ingest" again
Best regards,
Ada
4. Re: Prelude Crashing on "Ingest" Win7. 64
JohnnyMilk Apr 20, 2014 8:56 PM (in response to Ada_Wang)It seems to have worked. Hopefully after a few more tests... ill followup.
5. Re: Prelude Crashing on "Ingest" Win7. 64
Ada_Wang Apr 20, 2014 11:08 PM (in response to JohnnyMilk)Great to know.
6. Re: Prelude Crashing on "Ingest" Win7. 64
JohnnyMilk Apr 21, 2014 3:14 PM (in response to Ada_Wang)After getting it to work... now every time i scub through footage or after 10min or so Prelude automatically crashes. Is there are report I can generate for the application to send you?
How would I go about providing that?
7. Re: Prelude Crashing on "Ingest" Win7. 64
Ada_Wang Apr 22, 2014 3:02 AM (in response to JohnnyMilk)Hi Johnny,
If you could post the screen video of your issue to our file server that would be very helpful. Please reach me at weiwang@adobe.com, I'll let you know our server address and the credentials.
Ada
8. Re: Prelude Crashing on "Ingest" Win7. 64
SOUTH_Director Nov 5, 2014 9:36 AM (in response to Ada_Wang)Hi Ada
I faced the same issue, I opendI did all steps you suggest with the only difference I renamed ADOBE in mi local directory C:\Users\vimere\Documents\Adobe even if I also see the same folder in Public folder C:\Users\Public\Documents but once I delete it it willl never appear again. Maybe is a refuse of my old Adobe installation (CS6, CC8).
My licence is a company one for VIacom
9. Re: Prelude Crashing on "Ingest" Win7. 64
Kevin Monahan Nov 5, 2014 3:38 PM (in response to SOUTH_Director)Hi SD,
Can you try updating Prelude to the current version?
Kevin
10. Re: Prelude Crashing on "Ingest" Win7. 64
SOUTH_Director Nov 6, 2014 5:17 AM (in response to Kevin Monahan) -
11. Re: Prelude Crashing on "Ingest" Win7. 64
SOUTH_Director Nov 7, 2014 9:51 AM (in response to SOUTH_Director)Let me add some informations. I formatted an other PC and installed the CC and I can see the latest release 2014.1. Unfortunately I cannot format my laptop but I copied the same installer ver 2.8.1.451.The tool installed the old release 2014 with the same issue.
I've been heard that the only way to instal the lates version is format the HDD?
Is it true?
Thank you for helping me inthis
12. Re: Prelude Crashing on "Ingest" Win7. 64
SOUTH_Director Nov 9, 2014 5:32 AM (in response to SOUTH_Director)As we use to say in Italy "me la suono e me la canto" translated "I play myself and I sing myself" which means I raise the question, I eas hungry for that but then I was the cause of the problem.
Here how it has been solved.
Under menu Edit / Preferences / General / media
click on clean "Media Cache Database". It take a while to reply particularly if your foder is quiete full like was mine (30GB)!!
Once cleaned everythinhg goes fine.
I did probably something wrong, I've been using Prelude a lot but I didn't know I should have cleaned. I'll ask to my to my Adobe Tutor Paolo Baccolo.
Thank you anyway to assist us in this.
Emanuele
13. Re: Prelude Crashing on "Ingest" Win7. 64
emanuele de capitani Nov 10, 2014 3:28 AM (in response to SOUTH_Director)I have the same issue, Updated to latest 2014.1, updated Graphic card as suggested in different forum and now not only Prelude but also Premiere Pro doesn't work!!!
Any Idea?
14. Re: Prelude Crashing on "Ingest" Win7. 64
SOUTH_Director Nov 10, 2014 3:32 AM (in response to emanuele de capitani)once I solved the issue deleting the cache database I've been worked for few hours and then Prelude crashed again. I Update CC to lates version and now ... Premiere CC 2014.1 crashes too
Someone suggested me to rebuild the workstation. Is this the only way to fix the issue?
I tried also to update graphic card but nothing has been changed
