Like for this code collapse not work properly:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html"; charset="utf-8"/>
<title>
Untitled Document
</title>
</head>
<body>
<div class="container body-content">
<div class="row Heading">
<div class="col-md-12 ">
<h3>
Product Search
</h3>
</div>
</div>
<div id="ProgressIndicator">
<div>
</div>
<!-- this will do the vertical align -->
<img alt="Loading.." src="Images/loading.gif"/>
</div>
<div class="row">
<div class="col-md-3 columnleft">
<div class="row">
<div class="col-md-12">
<h6>
RESULTS :
<select id="resultRange">
<option value="100">
100
</option>
<option value="200">
200
</option>
<option value="500">
500
</option>
<option value="1000">
1000
</option>
<option value="2000">
2000
</option>
<option value="3000">
3000
</option>
<option value="4000">
4000
</option>
<option value="5000">
5000
</option>
</select>
</h6>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
Moreover, I tried your code snippet. If you look at the below screen shot, the code collapses properly.
And its not collapsing the code below that. If you close a parent tag, then the sub tags will also close.
Anit Kumar
Screenshot of the problem? Or are you talking about the indenting being off?
-Carl V.
In this screen shot you can see that blcok of div not collapse proper way...When i try to minimize div block then all the code after that div minimize.
I'm not seeing anything obviously wrong with that code. That said, the Aptana plugin used by CFBuilder 2 has always been a bit "dodgy". If you can, try downloading the beta version of CFBuilder 3 ( http://www.adobe.com/cfusion/entitlement/index.cfm?e=labs_coldfusion11 ) and try it out. They ripped out Aptana and rewrote the HTML-handling parts. It's much faster and seems much more reliable.
-Carl V.
I know nothing is wrong in this code...All code is right but i think you dont understand my issue..My issue is when i collapse(minimize) any div block ya any other tag like <flayout> then collapse whole code after that div tag...form that div tag to HTML tag..
@Shraddha,
I only mentioned the code looking OK because I've had issues with code collapse when there were syntax issues with opening/closing tags. So I was ruling that out as your issue.
Again, what you are seeing might just be a problem with the Aptana plugin that CFBuilder 2 uses. Adobe bootstrapped HTML/JS/CSS/CFML code formatting and syntax highlighting support by leveraging Aptana in CFB1 & CFB2. Adobe ditched Aptana and completely rewrote the HTML/JS/CSS/CFML stuff for CFB3, which is why I suggested downloading the beta and trying it out - that would confirm if you indeed are seeing a "bug" in CFBuilder that has been resolved in CFB3.
-Carl V.
@Shraddha,
Can you try CFB3 as suggested by Carl V and see, if you are still getting the code "collapse issue" or not?
Anit Kumar
No i dont try...I dont want to beta version of CFB3
Shraddha,
Since my post on April 25th, Adobe has released the actual ColdFusion Builder version 3 (not beta). Download the trial version and see if the problems are fixed. If they are, then you can decide whether to buy the CFBuilder upgrade.
-Carl V.
Anit Kumar
Ok Thanks...
