1. Re: Photomerge: arrange image sequence manually
JJMack Apr 22, 2014 10:14 AM (in response to G.Hoffmann) -
2. Re: Photomerge: arrange image sequence manually
G.Hoffmann Apr 22, 2014 10:26 AM (in response to JJMack)Thanks for the confirmation – in newer versions of Photomerge the sequence of shots
cannot be arranged manually. In my opinion, this is a mistake. The photographer knows
the sequence – why should he leave the riddling & fiddling to the poor software?
Yes, the three or four shots are clearly overlapping, but this doesn't help much, if the
image content is almost the same.
I found an intermediate solution:
Given are from left to right four shots P1, P2, P3, P4.
a) Photomerge P1+P2=>P12 and save
b) Photomerge P3+P4=>P34 and save
c) Photomerge P12+P34=>P1234
Again, the manual arrangement is a very reasonable option – should be re-established
(but not for me - I'm sticking to CS6).
Best regards --Gernot Hoffmann
3. Re: Photomerge: arrange image sequence manually
JJMack Apr 22, 2014 11:24 AM (in response to G.Hoffmann)If you really want to stitch images together. You should look into good stitching software designed for stitching. They are much better then poor photographer that know the sequence of image. The have many tools the Photographer can use to help in the stitching process to improve things.
Please check out this one and use the web site full screen mode to get the best experience there http://www.paris-26-gigapixels.com/index-en.html
Photomerge does not even support fisheye lenses but fits well with Photoshop jack of all thing thing.
