1. Re: Installed extensions not showing windows>extensions pull down?
fgregor Apr 22, 2014 2:23 AM (in response to AJCameron)Hi AJCameron,
Can you please check whether the products you've installed are listed in Extension Manager CC or Extension Manager CS6?
If they are listed in Extension Manager CC, but they are not appearing in Photoshop CC, can you please tell me the exact version of Photoshop you're using, and check whether folders corresponding to the missing extensions can be found in either of these locations? [In Finder, use Go -> Go to Folder...]:
- ~/Library/Application Support/Adobe/CEPServiceManager4/extensions
- /Library/Application Support/Adobe/CEPServiceManager4/extensions
Best wishes,
Fraser
2. Re: Installed extensions not showing windows>extensions pull down?
AJCameron Apr 22, 2014 3:22 AM (in response to fgregor)Fraser,
I'm using Extension Manager CC, & Photoshop CC (14.2.1 x64)
the folder ... /Library/Application Support/Adobe/CEPServiceManager4/extensions, doesn't contain the installed missing extensions, only
>Adobe Mini Bridge 3
>AdobeExchange
>com.adobe.behance.sharonbehance.htnl
>KulerPanelBundle
>SearchForHelp
Note I have found the missing associated XMP files within:
/Library/Application Support/Adobe/Extension Manager CC/EM Store/Photoshop
is this correct?
...Alan
3. Re: Installed extensions not showing windows>extensions pull down?
fgregor Apr 22, 2014 4:14 AM (in response to AJCameron)Hi Alan,
Thanks for this information. Can you also tell me whether or not such folders exist here?:
/Applications/Adobe Photoshop CC/Plug-ins/Panels
I've just tried installing those particular products with that version of Photoshop, and this is where they end up.
If the folders aren't there, could you please enable logging as follows and send me the log files at fgregor at adobe dot com?
Create a file called 'ExManCoreLibLog.YES' and place it in the following location:
/Users/<username>/Library/Application Support/Adobe/Extension Manager CC/Log/ExManCoreLibLog.YES
Then create a file named 'ExManLog.YES' and place it at:/Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/ExManLog.YES
Both log files are generated and saved in the following location:
Many thanks,
Fraser
4. Re: Installed extensions not showing windows>extensions pull down?
AJCameron Apr 22, 2014 7:19 AM (in response to fgregor)Fraser,
the /Applications/Adobe Photoshop CC/Plug-ins/Panels folder exists but is empty?
I completed the other instructions as requested, re-started PS CC & Extension manager CC, but no log file is produced.... is reboot required?
I'm also assuming to create ExManCoreLibLog.YES & ExManLog.YES, I just rename a blank txt file?
...Alan
5. Re: Installed extensions not showing windows>extensions pull down?
fgregor Apr 22, 2014 9:43 AM (in response to AJCameron)Hi Alan,
Yes - it would probably be easiest to reboot after having created those files to enable logging. You can create those files by renaming a blank text file, or you can use the Terminal with the following commands:
- sudo touch ~/Library/Application\ Support/Adobe/Extension\ Manager\ CC/Log/ExManCoreLibLog.YES
- sudo touch /Applications/Adobe\ Extension\ Manager\ CC/Adobe\ Extension\ Manager\ CC.app/Contents/MacOS/ExManLog.YES
Certainly the fact that the folders are missing from the Panels folder suggests that something has gone wrong during the installation, rather than this being a problem with Photoshop itself. These log files should tell us what went wrong.
Thanks for your perseverance.
Fraser
6. Re: Installed extensions not showing windows>extensions pull down?
AJCameron Apr 22, 2014 11:11 AM (in response to fgregor) -
7. Re: Installed extensions not showing windows>extensions pull down?
fgregor Apr 23, 2014 8:50 AM (in response to AJCameron)Hi Alan,
That is quite strange indeed.
Can you please try the following steps, and let me know the outcome?
- In terminal, check the result of this command:
- ls ~/Library/Application\ Support/Adobe/Extension\ Manager\ CC/Temp/ | grep AdobePaper
- If a ZXP file such as com.AdobePaperTexturePro_2.0.2_4ecbd5.zxp exists,
- In terminal:
- cp ~/Library/Application\ Support/Adobe/Extension\ Manager\ CC/Temp/com.AdobePaperTexturePro_2.0.2_4ecbd5.zxp ~/Desktop
- Uninstall Adobe Paper Textures Pro in Extension Manager CC (with Photoshop closed)
- In terminal:
/Applications/Adobe\ Extension\ Manager\ CC/Adobe\ Extension\ Manager\ CC.app/Contents/MacOS/ExManCmd --install ~/Desktop/com.AdobePaperTexturePro_2.0.2_4ecbd5.zxp
- In terminal:
It would also be good if you could let me know the exact name and size of the AdobePaperTexturePro_....zxp file that is copied to your Desktop.
Best regards,
Fraser
8. Re: Installed extensions not showing windows>extensions pull down?
AJCameron Apr 23, 2014 10:59 AM (in response to fgregor)Fraser,
no such file found on machine!
alancameronsmbp:~ Alan-Cameron$ cp ~/Library/Application\ Support/Adobe/Extension\ Manager\ CC/Temp/com.AdobePaperTexturePro_2.0.2_4ecbd5.zxp ~/Desktop
cp: /Users/Alan Cameron/Library/Application Support/Adobe/Extension Manager CC/Temp/com.AdobePaperTexturePro_2.0.2_4ecbd5.zxp: No such file or directory
I done a little more digging & found this >
...Alan
9. Re: Installed extensions not showing windows>extensions pull down?
fgregor Apr 28, 2014 2:07 AM (in response to AJCameron)Hi Alan,
This at least suggests that the version you attempted to install was not the same version that I have on my machine. Can you please go to the folder
/Users/Alan Cameron/Library/Application\ Support/Adobe/Extension\ Manager\ CC/Temp/
and check to see whether there is any file at all starting with com.AdobePaperTexturePro?
If so, can you try again with the commands with my previous post (but using this correct filename)?
P.S. Your screenshot looks like the folder you would find in /Library/Application support; not ~/Library/Application Support (note the tilde at the start - this is a hidden folder inside your user's home folder). Can you try again using Go -> Go to Folder in Finder, if you haven't done so already?
Many thanks,
Fraser
10. Re: Installed extensions not showing windows>extensions pull down?
AJCameron Apr 30, 2014 2:11 PM (in response to fgregor)Fraser,
thanks for your patience, but I'm afraid mine has run out, ..... it's just not worth the bother!
....Alan
