Hello, everyone.
I've been tasked with a project that will involve querying a table on one server, then sending the data to a remote server that will take the data and insert it into another database (the two db cannot communicate directly with each other.)
I've never had to do something like this, before. What is the best way to achieve the desired results? Is there a way to "submit" a query (anywhere from 1 to 5 records at any given time) to the remote server without incorporating WDDX?
CF9 environment, soon to be CF10.
V/r,
^_^
Hi, @BKBK,
Not permitted.
It's kind of tedious, but what I've worked, so far, is to have CF1 select data from DB1, SerializeJSON the data, use cfhttp to POST the data to CF2.
THEN, CF2 DeserializeJSON the data back into a query object and insert that into DB2.
Unless you think there's a better way to do it?
V/r,
^_^
What is running on the remote server? ColdFusion, .Net, PHP, Ruby, etc.? Or is the remote server the other database server?
-Carl V.
Hello, Carl,
Thanks for your reply. The receiving server is a CF server hooked to another db.
V/r,
^_^
WolfShade wrote:
... querying a table on one server, then sending the data to a remote server that will take the data and insert it into another database (the two db cannot communicate directly with each other.)
So, you have 4 servers: CF1<=>DB1 and CF2<=>DB2. What about CF1 bypassing CF2, and inserting the data to DB2?
Hi, @BKBK,
Not permitted.
V/r,
^_^
@WolfShade
Sounds cool!
Thank you, @BKBK. I'll complete that procedure and mark it as correct.
^_^
I agree with @BKBK. Sorry for not following up yesterday; I was away from my desk all day.
-Carl V.
No worries, Carl. I appreciate all opinions on this matter, whether they concur or differ.
I'm in the process of finishing it. Minor tweaks, error trapping, etc.
V/r,
^_^
