Hello guys,
I`ve been struggling to translate my eCommerce website to portuguese. So far Mario`s post has been of some help (http://forums.adobe.com/docs/DOC-1808). However it does not show how to translate the strings "No one is logged in" and "Shopping cart is empty", after some research I`ve found that quite a few people wants to know how to do that but all the posts related to this are over a year old that might be the reason why the solution I found in this post (http://forums.adobe.com/message/4848069) did not work. There Frank said to add the following script:
<!--This script translates "Shopping cart is empty" in something else.-->
<script type="text/javascript">
$.fn.replaceText = function( search, replace, text_only ) {
return this.each(function(){
var node = this.firstChild,
val,
new_val,
remove = [];
if ( node ) {
do {
if ( node.nodeType === 3 ) {
val = node.nodeValue;
new_val = val.replace( search, replace );
if ( new_val !== val ) {
if ( !text_only && /</.test( new_val ) ) {
$(node).before( new_val );
remove.push( node );
} else {
node.nodeValue = new_val;
} while ( node = node.nextSibling );
remove.length && $(remove).remove();
$(".cartSummaryItem").replaceText( "Shopping cart is empty.", "Your own translation." );
</script>
right before the </body> tag. On the same post they were asking on how to translate quite a few other modules but all I need are those two, the site is supposed to be released in a week and I still couldn`t figure out how to do it manually since BC does not offer portuguese as a culture for the domain I`m using (http://www.primenutricao.com.br).
Cheers,
Alex.
