Following the advice for a different thread (someone who couldn't install on Windows 8), I tried what they said, but it still failed to install. Here is a snippit of the results:
You shouldn't be using the MSI installer if you do not have any specific problem with the EXE installer. Use the installers from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#main-pars_tex...
As I mentioned at the beginning, I had already tried the normal install, using the .exe. It downloads, then starts the intstall. Before it goes very far it stops and then says that there is a General Install Error. That is the reason I looked at other posts to see if there was an answer. The above was an alternative method suggested. Hence I tried it. So, I am no further along with this problem. I have tried the normal install again with the same error results. I'm at a loss.
Can you post the contents of the FlashInstall.log file in C:\Windows\System32\Macromed\Flash (and C:\Windows\Syswow64\Macromed\Flash if you are on 64-bit Windows).
I appreciate your continued patience and help.
The log is massive. The first error I notice is about 2/3 of the way down in the file. It is at line:
=X====== M/11.8.800.94 2013-07-23+19-01-58.165 ========
======== M/10.1.52.14 2010/05/02 00:07:54.678 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\InstallAX.exe" -install activex -msi
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10g.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10g_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10g_ActiveX.dll
======== M/10.1.52.14 2010/06/26 03:17:31.932 ========
0000 00000010 C:\Windows\system32\Macromed\Flash\FlashUtil10g_ActiveX.exe -uninstall activex -msi
0001
0002 00000012
=O====== M/10.1.53.64 2010-06-26+03-17-16.285 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\37BD.dir\InstallFlashPlayer.exe"
0001
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash10h.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10h_ActiveX.dll
=X====== M/10.1.53.64 2010-06-26+03-17-36.705 ========
=O====== M/10.1.82.76 2010-08-14+15-26-45.035 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\DF6.dir\InstallFlashPlayer.exe"
0001
0002
0003
0004
0005
0006
0007
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10i_Plugin.exe
0010 00000017 C:\Windows\system32\Macromed\Flash
=X====== M/10.1.82.76 2010-08-14+15-27-34.939 ========
=O====== M/10.1.82.76 2010-08-21+02-10-06.396 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\AFCF.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10i.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10i_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10i_ActiveX.dll
=X====== M/10.1.82.76 2010-08-21+02-11-43.638 ========
=O====== M/10.1.85.3 2010-09-24+21-10-47.134 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\B8FE.dir\InstallFlashPlayer.exe" -iv 0
0001
0002 00000018
0003
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash10k.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10k_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10k_ActiveX.dll
=X====== M/10.1.85.3 2010-09-24+21-11-37.235 ========
=O====== M/10.1.85.3 2010-10-27+04-53-29.941 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\4DB6.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10k_Plugin.exe
0009 00000017 C:\Windows\system32\Macromed\Flash
=X====== M/10.1.85.3 2010-10-27+05-00-11.789 ========
=O====== M/10.1.102.64 2010-11-09+00-33-24.090 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\6F75.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
=X====== M/10.1.102.64 2010-11-09+00-37-59.851 ========
=O====== M/10.1.102.64 2010-11-25+17-47-21.363 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\974.dir\InstallFlashPlayer.exe" -iv 0
0001
0002 00000018
0003
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash10l.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10l_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10l_ActiveX.dll
=X====== M/10.1.102.64 2010-11-25+17-47-30.810 ========
=O====== M/10.1.102.64 2010-12-30+03-26-47.327 ========
0000 00000010 "C:\ProgramData\NOS\Adobe_Downloads\install_flash_player_ax.exe"
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10l.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10l_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10l_ActiveX.dll
=X====== M/10.1.102.64 2010-12-30+03-28-21.232 ========
=O====== M/10.2.152.26 2011-02-10+21-01-12.880 ========
0000 00000010 "C:\Downloads\Internet\Adobe\install_flash_player.exe"
0001
0002
0003
0004
0005
0006
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10m_Plugin.exe
=X====== M/10.2.152.26 2011-02-10+21-01-59.931 ========
=O====== M/10.2.152.26 2011-02-19+00-11-52.422 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\C67B.dir\InstallFlashPlayer.exe" -iv 0
0001
0002 00000018
0003
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash10m.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10m_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10m_ActiveX.dll
=X====== M/10.2.152.26 2011-02-19+00-12-30.742 ========
=O====== M/10.2.152.32 2011-03-07+10-14-27.875 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\475C.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10n.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10n_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10n_ActiveX.dll
=X====== M/10.2.152.32 2011-03-07+10-14-40.293 ========
=O====== M/10.2.153.1 2011-03-27+06-07-14.666 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\BFD6.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10o.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10o_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10o_ActiveX.dll
=X====== M/10.2.153.1 2011-03-27+06-07-28.145 ========
=O====== M/10.2.153.1 2011-04-12+01-31-55.964 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\6B60.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10o_Plugin.exe
=X====== M/10.2.153.1 2011-04-12+01-32-08.818 ========
=O====== M/10.2.159.1 2011-04-19+15-08-42.606 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\C16C.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10p_Plugin.exe
=X====== M/10.2.159.1 2011-04-19+15-09-03.041 ========
=O====== M/10.2.159.1 2011-04-25+16-51-59.760 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\3D10.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10p.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10p_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10p_ActiveX.dll
=X====== M/10.2.159.1 2011-04-25+16-52-47.433 ========
======== M/10.1.52.14 2011/04/29 19:19:21.526 ========
0001
======== M/10.1.52.14 2011/04/29 19:19:27.675 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\InstallPlugin.exe" -install plugin -msi
0001
=O====== M/10.3.181.14 2011-05-23+02-33-43.375 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\21A4.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10q.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10q_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10q_ActiveX.dll
0004 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
=X====== M/10.3.181.14 2011-05-23+02-36-10.026 ========
=O====== M/10.3.181.23 2011-06-07+23-38-45.795 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\57C1.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10s.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10s_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10s_ActiveX.dll
0005
=X====== M/10.3.181.23 2011-06-07+23-39-05.323 ========
=O====== M/10.3.181.26 2011-06-16+13-36-58.728 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\931F.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10t_Plugin.exe
0010 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0011
=X====== M/10.3.181.26 2011-06-16+13-37-53.910 ========
=O====== M/10.3.181.26 2011-06-23+19-45-20.442 ========
0001
0002 00000018
0003
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash10t.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10t_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10t_ActiveX.dll
0009 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0010
=X====== M/10.3.181.26 2011-06-23+19-46-33.598 ========
=O====== M/10.3.181.26 2011-06-25+02-37-55.197 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\119E.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10t.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10t_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10t_ActiveX.dll
0005
=X====== M/10.3.181.26 2011-06-25+02-38-34.915 ========
=O====== M/10.3.181.34 2011-07-26+01-01-29.976 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\install_flash_player_ax.exe" -dlm -install
0001
0002 00000018
0003
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash10u.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10u_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10u_ActiveX.dll
0010 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0011
=X====== M/10.3.181.34 2011-07-26+01-01-36.343 ========
=O====== M/10.3.181.34 2011-07-29+21-33-37.033 ========
0001
=X====== M/10.3.181.34 2011-07-29+21-33-38.825 ========
=O====== M/10.3.181.34 2011-07-29+21-34-22.865 ========
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10u.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10u_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10u_ActiveX.dll
0005 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006
=X====== M/10.3.181.34 2011-07-29+21-34-28.525 ========
=O====== M/10.3.181.34 2011-07-30+00-38-34.024 ========
0001
=X====== M/10.3.181.34 2011-07-30+00-38-35.480 ========
=O====== M/10.3.181.34 2011-07-30+00-39-08.336 ========
0006
=X====== M/10.3.181.34 2011-07-30+00-39-12.327 ========
=O====== M/10.3.183.5 2011-08-16+14-45-01.125 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\E55F.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10v.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10v_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10v_ActiveX.dll
0006
=X====== M/10.3.183.5 2011-08-16+14-45-28.379 ========
=O====== M/10.3.183.5 2011-08-17+00-23-10.880 ========
0000 00000010 "C:\Downloads\Adobe\install_flash_player.exe"
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10v_Plugin.exe
0011 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0012 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0013
=X====== M/10.3.183.5 2011-08-17+00-23-33.967 ========
=O====== M/10.3.183.7 2011-08-29+22-30-25.851 ========
0001
0002 00000018
0003
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash10w.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10w_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10w_ActiveX.dll
0011
=X====== M/10.3.183.7 2011-08-29+22-30-36.339 ========
=O====== M/10.3.183.10 2011-09-25+19-39-24.820 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\26E1.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10x_Plugin.exe
0013
=X====== M/10.3.183.10 2011-09-25+19-39-38.845 ========
=O====== M/10.3.183.10 2011-10-01+19-59-16.483 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\74C2.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10x.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10x_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10x_ActiveX.dll
0006
=X====== M/10.3.183.10 2011-10-01+19-59-55.097 ========
=O====== M/11.0.1.152 2011-10-17+03-01-31.077 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\3ED4.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash11c.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
0007 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0008
=X====== M/11.0.1.152 2011-10-17+03-01-49.425 ========
=O====== M/11.0.1.152 2011-11-07+17-30-14.204 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\install_flash_player_ax_32bit.exe" -dlm -install
0001
=X====== M/11.0.1.152 2011-11-07+17-30-16.388 ========
=O====== M/11.0.1.152 2011-11-07+17-31-54.313 ========
0001
=X====== M/11.0.1.152 2011-11-07+17-31-55.968 ========
=O====== M/11.0.1.152 2011-11-07+17-32-15.704 ========
0001
=X====== M/11.0.1.152 2011-11-07+17-32-17.463 ========
=O====== M/11.0.1.152 2011-11-07+17-33-28.367 ========
0001
=X====== M/11.0.1.152 2011-11-07+17-33-31.027 ========
=O====== M/11.0.1.152 2011-11-07+17-34-45.359 ========
0001 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash11c.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11c_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11c_ActiveX.dll
0005 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006
=X====== M/11.0.1.152 2011-11-07+17-34-51.415 ========
=O====== M/11.0.1.152 2011-11-09+18-56-48.631 ========
0001
=X====== M/11.0.1.152 2011-11-09+18-56-50.505 ========
=O====== M/11.0.1.152 2011-11-09+18-57-28.393 ========
0006
=X====== M/11.0.1.152 2011-11-09+18-57-46.851 ========
=O====== M/11.1.102.55 2011-11-11+01-13-57.822 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\CCCB.dir\InstallFlashPlayer.exe" -iv 0
0002
0003
0004
0005
0006
0007
0008
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11e_Plugin.exe
0011 00000017 C:\Windows\system32\Macromed\Flash
0012 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0013
=X====== M/11.1.102.55 2011-11-11+01-16-07.539 ========
=O====== M/11.1.102.55 2011-12-06+18-44-45.450 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\F400.dir\InstallFlashPlayer.exe" -iv 4
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash11e.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11e_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11e_ActiveX.dll
0006 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0007
=X====== M/11.1.102.55 2011-12-06+18-45-08.806 ========
=O====== M/11.1.102.62 2012-02-20+21-09-03.985 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\C458.dir\InstallFlashPlayer.exe" -iv 4
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash11f.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.dll
0007
=X====== M/11.1.102.62 2012-02-20+21-09-33.936 ========
=O====== M/11.1.102.63 2012-03-05+22-20-22.896 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\AE39.dir\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11g_Plugin.exe
0012 00000017 C:\Windows\system32\Macromed\Flash
0013 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0014
=X====== M/11.1.102.63 2012-03-05+22-21-10.461 ========
=O====== M/11.1.102.63 2012-03-13+22-22-11.761 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash11g.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11g_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11g_ActiveX.dll
0011
=X====== M/11.1.102.63 2012-03-13+22-22-19.901 ========
=O====== M/11.2.202.228 2012-04-06+22-55-35.863 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\4115.dir\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_2_202_228.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_Plugin.exe
0014
0015 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0016
0017
0018 00000012
=X====== M/11.2.202.228 2012-04-06+23-05-42.480 ========
=O====== M/11.2.202.228 2012-04-06+23-21-03.934 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0002
0003 00000018
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
0008 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0009
0010
0011 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0012
0013
0014
0015 00000012
=X====== M/11.2.202.228 2012-04-06+23-21-23.792 ========
=O====== M/11.2.202.233 2012-04-14+07-21-11.165 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_233.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_233_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_233_ActiveX.dll
0011
0012
0013 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0014
0015
0016
0017 00000012
=X====== M/11.2.202.233 2012-04-14+07-21-30.450 ========
=O====== M/11.2.202.233 2012-04-14+08-21-04.322 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_2_202_233.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_233_Plugin.exe
0014
0015
0016 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0017
0018
0019
0020 00000012
=X====== M/11.2.202.233 2012-04-14+08-21-12.116 ========
=O====== M/11.2.202.233 2012-04-19+22-29-35.937 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\install_flash_player_32bit.exe" -iv 8 -install
0001
=X====== M/11.2.202.233 2012-04-19+22-29-37.323 ========
=O====== M/11.2.202.233 2012-04-19+22-29-56.477 ========
0001
=X====== M/11.2.202.233 2012-04-19+22-29-57.733 ========
=O====== M/11.2.202.233 2012-04-19+22-30-04.289 ========
0002
0003
0004
0005
0006
0007
0008
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_2_202_233.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_233_Plugin.exe
0013
0014
0016
0017
0018
0019 00000012
=X====== M/11.2.202.233 2012-04-19+22-30-10.140 ========
=O====== M/11.2.202.233 2012-04-19+22-54-45.111 ========
0001
=X====== M/11.2.202.233 2012-04-19+22-54-46.404 ========
=O====== M/11.2.202.233 2012-04-19+22-55-01.620 ========
0002
0003
0004
0005
0006
0007
0008
0013
0014
0016
0017
0018
0019 00000012
=X====== M/11.2.202.233 2012-04-19+22-55-07.425 ========
2012-4-24+23-21-0.628 [error] 1221 1115
2012-5-5+13-21-10.534 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-05+13-21-04.613 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.2.202.235 2012-05-05+13-21-14.177 ========
2012-5-5+14-21-11.307 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-05+14-21-05.739 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_2_202_235.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_Plugin.exe
0013 00000017 C:\Windows\system32\Macromed\Flash
0014 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0015
0016
0017 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0018
0019
0020
0021 00000012
=X====== M/11.2.202.235 2012-05-05+14-21-13.372 ========
=O====== M/11.2.202.235 2012-05-11+22-33-54.542 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\install_flash_player_ax_32bit.exe" -iv 8 -install
0001
=X====== M/11.2.202.235 2012-05-11+22-33-55.848 ========
=O====== M/11.2.202.235 2012-05-11+22-34-20.385 ========
0002
0003 00000018
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
0006
=X====== M/11.2.202.235 2012-05-11+22-34-23.918 ========
=O====== M/11.2.202.235 2012-05-11+22-49-32.881 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{103E1F37-EB03-4D92-A7B5-0AC22D8B184F}\InstallFlashPlayer.exe" -iv 6
0002
0003
0004 00000018
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
0007
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.2.202.235 2012-05-11+22-50-40.438 ========
=O====== M/11.2.202.235 2012-05-11+22-49-29.167 ========
0000 00000010 C:\Users\sdbarker\AppData\Local\Temp\IDC2.tmp\FP_AX_CAB_INSTALLER64.exe
0001 00000011 1
=X====== M/11.2.202.235 2012-05-11+22-50-41.045 ========
=O====== M/11.3.300.257 2012-06-11+14-56-26.341 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\install_flash_player.exe" -install -iv 8
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_3_300_257.dll
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_257_Plugin.exe
0014 00000017 C:\Windows\system32\Macromed\Flash
0015 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0016
0017
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_3_300_257.exe
0019 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0020
0021
0022
0023 00000012
=X====== M/11.3.300.257 2012-06-11+14-56-31.971 ========
2012-6-24+0-21-10.452 [error] 1226 1062
=O====== M/11.3.300.262 2012-06-24+00-21-06.005 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_3_300_262.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_262_Plugin.exe
0014
0015
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_3_300_262.exe
0018
0019
0020
0021 00000012
=X====== M/11.3.300.262 2012-06-24+00-21-15.519 ========
2012-7-2+20-3-14.46 [error] 1226 1062
2012-7-2+20-4-18.138 [error] 1226 1062
=O====== M/11.3.300.257 2012-07-02+20-02-50.552 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{F721A044-75C6-4734-83A0-A9EF875B63CF}\InstallFlashPlayer.exe" -iv 4
0002
0003
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_3_300_257.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_257_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_257_ActiveX.dll
0008
0009
0010 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011
0012
0013
0014 00000012
=X====== M/11.3.300.257 2012-07-02+20-04-18.181 ========
=O====== M/11.3.300.265 2012-07-21+16-47-31.048 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{3EDF8581-7D97-440E-937F-961844A09C4A}\InstallFlashPlayer.exe" -iv 4
0002
0003 00000018
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_3_300_265.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_265_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_265_ActiveX.dll
0010
0011
0012 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013
0014 00000012
=X====== M/11.3.300.265 2012-07-21+16-48-01.910 ========
2012-7-21+17-29-12.235 [error] 1226 1062
=O====== M/11.3.300.265 2012-07-21+17-29-05.622 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_3_300_265.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_265_Plugin.exe
0014
0015
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_3_300_265.exe
0018
0019
0020
0021 00000012
=X====== M/11.3.300.265 2012-07-21+17-29-14.239 ========
=O====== M/10.2.153.1 2012-07-25+21-28-04.367 ========
0001
=X====== M/10.2.153.1 2012-07-25+21-28-05.422 ========
=O====== M/10.2.153.1 2012-07-25+21-28-10.705 ========
0001
=X====== M/10.2.153.1 2012-07-25+21-28-11.677 ========
2012-7-26+22-29-14.535 [error] 1226 1062
=O====== M/11.3.300.268 2012-07-26+22-29-09.246 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_3_300_268.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.3.300.268 2012-07-26+22-29-17.358 ========
2012-7-26+23-29-12.370 [error] 1226 1062
=O====== M/11.3.300.268 2012-07-26+23-29-07.210 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_3_300_268.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.exe
0014
0015
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
0018
0019
0020
0021 00000012
=X====== M/11.3.300.268 2012-07-26+23-29-14.474 ========
2012-8-3+6-29-11.144 [error] 1226 1062
=O====== M/11.3.300.270 2012-08-03+06-29-06.448 ========
0002
0003 00000018
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_3_300_270.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_270_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_270_ActiveX.dll
0009
0010
0012
0013
0014
0015 00000012
=X====== M/11.3.300.270 2012-08-03+06-29-13.628 ========
2012-8-3+7-29-10.947 [error] 1226 1062
=O====== M/11.3.300.270 2012-08-03+07-29-06.564 ========
cpl
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_3_300_270.dll
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_270_Plugin.exe
0016
0017
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_3_300_270.exe
0020
0021
0022
0023 00000012
=X====== M/11.3.300.270 2012-08-03+07-29-13.560 ========
2012-8-14+19-29-13.354 [error] 1226 1062
=O====== M/11.3.300.271 2012-08-14+19-29-07.044 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_3_300_271.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.3.300.271 2012-08-14+19-29-16.122 ========
2012-8-14+20-29-12.877 [error] 1226 1062
=O====== M/11.3.300.271 2012-08-14+20-29-08.295 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_3_300_271.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_Plugin.exe
0015
0016
0017 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_3_300_271.exe
0018 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0019
0020
0021
0022 00000012
=X====== M/11.3.300.271 2012-08-14+20-29-14.914 ========
=O====== M/11.4.402.265 2012-08-30+17-13-10.614 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.d0201db20f088f78787750192234a6cba1687e1a\install_flash_player_ax.exe" -install -iv 8
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_265.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_265_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_265_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.4.402.265 2012-08-30+17-14-44.901 ========
2012-9-3+21-29-0.225 [error] 1223 1056
=O====== M/11.4.402.265 2012-09-13+17-16-06.995 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.0d9d9581be080ee70a07b7ccb49042e5103dfb28\install_flash_player_ax.exe" -install -iv 8
0001
=X====== M/11.4.402.265 2012-09-13+17-16-08.597 ========
2012-9-21+11-29-9.746 [error] 1226 1062
=O====== M/11.4.402.278 2012-09-21+11-29-05.590 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_4_402_278.dll
0014 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_278_Plugin.exe
0015 00000017 C:\Windows\system32\Macromed\Flash
0016 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0017
0018
0019 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_4_402_278.exe
0020 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0021
0022
0023
0024 00000012
=X====== M/11.4.402.278 2012-09-21+11-29-12.971 ========
=O====== M/11.4.402.278 2012-09-21+13-31-05.970 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.c9e47bcdba5a65c2e30d0f3a2e02c127016a4e0b\install_flash_player_ax.exe" -install -iv 8
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_278.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_278_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_278_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.4.402.278 2012-09-21+13-31-20.476 ========
2012-10-9+6-29-22.40 [error] 1226 1062
=O====== M/11.4.402.287 2012-10-09+06-29-17.149 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_287.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.4.402.287 2012-10-09+06-29-25.746 ========
2012-10-9+7-29-13.385 [error] 1226 1062
=O====== M/11.4.402.287 2012-10-09+07-29-08.523 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_4_402_287.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_Plugin.exe
0015
0016
0017 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_4_402_287.exe
0019
0020
0021
0022 00000012
=X====== M/11.4.402.287 2012-10-09+07-29-17.054 ========
=O====== M/11.5.502.110 2012-11-09+19-19-57.514 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.d3d4cc74f15b3ed1e91aa5d68c883c825a981979\install_flash_player_ax.exe" -install -iv 8
0002
0003
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_110.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_110_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_110_ActiveX.dll
0007 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009
0010
0012
0013
0014
0015 00000012
=X====== M/11.5.502.110 2012-11-09+19-20-06.950 ========
2012-12-11+22-29-26.686 [error] 1226 1062
=O====== M/11.5.502.135 2012-12-11+22-29-16.533 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_135.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
0010 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0012
0013
0014 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0015
0016
0017
0018 00000012
=X====== M/11.5.502.135 2012-12-11+22-29-30.642 ========
2012-12-11+23-29-15.241 [error] 1226 1062
=O====== M/11.5.502.135 2012-12-11+23-29-07.717 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_135.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_Plugin.exe
0013 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0016
0017
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_135.exe
0020
0021
0022
0023 00000012
=X====== M/11.5.502.135 2012-12-11+23-29-17.163 ========
2013-1-8+23-29-15.26 [error] 1226 1062
=O====== M/11.5.502.146 2013-01-08+23-29-08.652 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_146.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.5.502.146 2013-01-08+23-29-18.430 ========
2013-1-9+0-29-14.551 [error] 1226 1062
=O====== M/11.5.502.146 2013-01-09+00-29-08.686 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_146.dll
0014 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_146_Plugin.exe
0015 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0016 00000017 C:\Windows\system32\Macromed\Flash
0017 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0018
0019
0020 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_146.exe
0021 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0022
0023
0024
0025 00000012
=X====== M/11.5.502.146 2013-01-09+00-29-16.966 ========
2013-2-8+5-29-15.604 [error] 1226 1062
=O====== M/11.5.502.149 2013-02-08+05-29-08.519 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_149.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.5.502.149 2013-02-08+05-29-19.122 ========
2013-2-8+6-29-14.848 [error] 1226 1062
=O====== M/11.5.502.149 2013-02-08+06-29-07.828 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_149.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_Plugin.exe
0016
0017
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_149.exe
0020
0021
0022
0023 00000012
=X====== M/11.5.502.149 2013-02-08+06-29-16.891 ========
=O====== M/11.6.602.168 2013-02-13+17-30-30.578 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.a161f8052470857666147aa5fba9fbd2b6cd6e27\install_flash_player.exe" -install -iv 8
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_168.dll
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe
0014 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_168.exe
0018
0019
0021
0022
0023
0024 00000012
=X====== M/11.6.602.168 2013-02-13+17-30-39.554 ========
=O====== M/11.6.602.168 2013-02-13+20-47-33.599 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{08A2E1F3-D0B2-499D-A073-8E36013D1718}\InstallFlashPlayer.exe" -iv 6
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_168.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.6.602.168 2013-02-13+20-48-11.106 ========
=O====== M/11.6.602.168 2013-02-13+20-47-15.969 ========
0001 00000011 1
=X====== M/11.6.602.168 2013-02-13+20-48-12.158 ========
2013-2-27+9-29-18.754 [error] 1226 1062
=O====== M/11.6.602.171 2013-02-27+09-29-08.492 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_171.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_171_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.6.602.171 2013-02-27+09-29-22.789 ========
2013-2-27+10-29-23.10 [error] 1226 1062
=O====== M/11.6.602.171 2013-02-27+10-29-10.150 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_171.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_171_Plugin.exe
0015 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_171.exe
0017
0018
0020
0021
0022
0023 00000012
=X====== M/11.6.602.171 2013-02-27+10-29-25.434 ========
2013-3-12+22-29-14.337 [error] 1226 1062
=O====== M/11.6.602.180 2013-03-12+22-29-08.156 ========
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.6.602.180 2013-03-12+22-29-17.672 ========
2013-3-12+23-29-16.817 [error] 1226 1062
=O====== M/11.6.602.180 2013-03-12+23-29-10.970 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_180.dll
0014 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe
0017 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_180.exe
0018 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0019
0020
0022
0023
0024
0025 00000012
=X====== M/11.6.602.180 2013-03-12+23-29-18.925 ========
2013-3-13+22-3-7.675 [error] 1226 1062
=O====== M/11.6.602.180 2013-03-13+22-02-48.337 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{25AFA7E2-45AD-4695-B99B-2380398E1DD3}\InstallFlashPlayer.exe" -iv 4
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0005 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0007
0008
0009 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0010
0011
0012
0013 00000012
=X====== M/11.6.602.180 2013-03-13+22-03-19.130 ========
2013-4-11+0-29-22.833 [error] 1221 1115
=O====== M/11.7.700.169 2013-04-11+00-38-34.507 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.d013e10bcfbce57b905b41c75705034a9d85d5a2\install_flash_player_ax.exe" -install -iv 10
0002
0003 00000018
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_7_700_169.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0012
0013
0015
0016
0017
0018 00000012
=X====== M/11.7.700.169 2013-04-11+00-38-43.449 ========
2013-5-1+16-29-9.567 [error] 1221 1115
=O====== M/11.7.700.169 2013-05-02+23-36-32.179 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.2c66bf108a39b977c9a90e5b2a689f1896946050\install_flash_player_ax.exe" -install -iv 8
0001
=X====== M/11.7.700.169 2013-05-02+23-36-33.791 ========
=O====== M/11.7.700.169 2013-05-02+23-37-08.976 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_7_700_169.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_169_ActiveX.dll
0007
0008
0010
0011
0012
0013 00000012
=X====== M/11.7.700.169 2013-05-02+23-37-18.426 ========
2013-5-15+14-29-18.343 [error] 1226 1062
=O====== M/11.7.700.202 2013-05-15+14-29-08.405 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 11
0002 00000013 C:\Windows\TEMP\{5AC3318C-76D9-45A8-92B9-0B20221EDC3A}\Flash32_11_7_700_202.ocx
0003 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
0006 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0008
0009
0011
0012
0013
0014 00000012
=X====== M/11.7.700.202 2013-05-15+14-29-22.913 ========
2013-5-15+15-29-19.412 [error] 1226 1062
=O====== M/11.7.700.202 2013-05-15+15-29-11.576 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_7_700_202.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_Plugin.exe
0015 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_7_700_202.exe
0017
0018
0020
0021
0022
0023 00000012
=X====== M/11.7.700.202 2013-05-15+15-29-22.780 ========
2013-6-12+16-29-33.56 [error] 1226 1062
=O====== M/11.7.700.224 2013-06-12+16-29-16.764 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\TEMP\{0D0FB31C-F43F-4235-B59D-F96F02248F09}\Flash32_11_7_700_224.ocx
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
0013 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0015
0016
0018
0019
0020
0021 00000012
=X====== M/11.7.700.224 2013-06-12+16-29-38.992 ========
2013-6-12+17-29-25.76 [error] 1226 1062
=O====== M/11.7.700.224 2013-06-12+17-29-08.696 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015 00000014 C:\Windows\TEMP\{4EDE31EC-8190-4D50-9B26-DFFDD3014E8D}\NPSWF32_11_7_700_224.dll
0016 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_Plugin.exe
0017 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_Plugin.exe
0018 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0019 00000017 C:\Windows\system32\Macromed\Flash
0020 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_7_700_224.exe
0021 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0022
0023
0024 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0025
0026
0027
0028 00000012
=X====== M/11.7.700.224 2013-06-12+17-29-27.824 ========
=O====== M/11.8.800.94 2013-07-20+00-00-36.925 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Adobe\AIH.cf61c5c599dc5c18012fed621ac63a7e446617ec\install_flash_player.exe" -install -iv 10
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_8_800_94.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_Plugin.exe
0012 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_8_800_94.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/11.8.800.94 2013-07-20+00-01-00.658 ========
=O====== M/11.8.800.94 2013-07-23+19-01-43.780 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Adobe\AIH.0a46d016ff09e7cda1c9d4f01b1568c62571be11\install_flash_player_ax.exe" -install -iv 10
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_94.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0012 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0014
0015
0017
0018
0019
0020 00000012
2013-8-25+23-29-0.228 [error] 1223 1056
2013-8-27+0-29-0.253 [error] 1223 1056
2013-9-9+3-29-0.251 [error] 1223 1056
2013-9-10+4-29-0.229 [error] 1223 1056
2013-9-11+5-29-0.238 [error] 1223 1056
2013-9-11+5-29-21.605 [error] 1226 1062
=O====== M/11.8.800.168 2013-09-11+05-29-09.981 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\TEMP\{696C3A81-8F16-4D71-80F9-71F80C8C91A4}\Flash32_11_8_800_168.ocx
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_168_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/11.8.800.168 2013-09-11+05-29-28.882 ========
2013-9-11+6-29-14.899 [error] 1226 1062
=O====== M/11.8.800.168 2013-09-11+06-29-05.771 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\TEMP\{583F0FAB-6EA1-49DA-9E55-BD6906515337}\NPSWF32_11_8_800_168.dll
0011 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_168_Plugin.exe
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_168_Plugin.exe
0015 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_8_800_168.exe
0017
0018
0020
0021
0022
0023 00000012
=X====== M/11.8.800.168 2013-09-11+06-29-16.890 ========
2013-9-13+8-29-0.237 [error] 1223 1056
2013-9-13+8-29-20.317 [error] 1226 1062
=O====== M/11.8.800.174 2013-09-13+08-29-04.831 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009
0010 00000013 C:\Windows\TEMP\{C09EB266-08BD-413F-B28D-A55877FD7724}\Flash32_11_8_800_174.ocx
0011 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.exe
0013 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_174_ActiveX.dll
0014 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0016
0017
0019
0020
0021
0022 00000012
=X====== M/11.8.800.174 2013-09-13+08-29-23.820 ========
2013-9-13+9-29-0.264 [error] 1223 1056
2013-9-14+10-29-0.249 [error] 1223 1056
2013-9-15+11-29-0.238 [error] 1223 1056
2013-9-16+12-29-0.233 [error] 1223 1056
2013-9-20+16-29-14.877 [error] 1226 1062
=O====== M/11.8.800.175 2013-09-20+16-29-04.906 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\TEMP\{39897E97-9202-44BA-85BE-7FAEC871EAD2}\Flash32_11_8_800_175.ocx
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/11.8.800.175 2013-09-20+16-29-19.492 ========
2013-10-6+8-29-0.231 [error] 1223 1056
2013-10-7+9-29-0.236 [error] 1223 1056
2013-10-8+10-29-0.237 [error] 1223 1056
2013-10-9+11-29-0.239 [error] 1223 1056
2013-10-9+11-29-17.112 [error] 1226 1062
=O====== M/11.9.900.117 2013-10-09+11-29-06.220 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_117.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/11.9.900.117 2013-10-09+11-29-21.215 ========
2013-10-9+12-29-24.504 [error] 1226 1062
=O====== M/11.9.900.117 2013-10-09+12-29-10.274 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_9_900_117.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/11.9.900.117 2013-10-09+12-29-26.787 ========
2013-10-9+13-29-0.256 [error] 1223 1056
=O====== M/11.9.900.152 2013-11-16+18-38-30.761 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_152.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/11.9.900.152 2013-11-16+18-39-18.077 ========
2013-12-10+20-29-20.131 [error] 1226 1062
=O====== M/11.9.900.170 2013-12-10+20-29-07.835 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\TEMP\{981F95EC-261C-435E-9675-84C0734A2268}\Flash32_11_9_900_170.ocx
0010 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/11.9.900.170 2013-12-10+20-29-26.321 ========
2013-12-10+21-29-18.746 [error] 1226 1062
=O====== M/11.9.900.170 2013-12-10+21-29-06.155 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\TEMP\{3E6F156B-602D-4727-A23D-080CF7E74159}\NPSWF32_11_9_900_170.dll
0011 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
0015 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_9_900_170.exe
0017
0018
0020
0021
0022
0023 00000012
=X====== M/11.9.900.170 2013-12-10+21-29-20.844 ========
=O====== M/11.9.900.170 2013-12-24+05-41-02.239 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Adobe\AIH.f9df3a03a30afa8e6fc8b0db4887f9c0345965da\install_flash_player.exe" -install -iv 8
0001
=X====== M/11.9.900.170 2013-12-24+05-41-06.067 ========
=O====== M/11.9.900.170 2013-12-24+05-41-23.730 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_9_900_170.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_9_900_170.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/11.9.900.170 2013-12-24+05-41-33.703 ========
2013-12-25+7-29-0.231 [error] 1223 1056
=O====== M/12.0.0.39 2013-12-29+16-50-03.254 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_39_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/12.0.0.39 2013-12-29+16-50-03.268 ========
=O====== M/12.0.0.39 2013-12-29+16-49-39.999 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\ANKMS1SW\Adobe_Flash_Player_(IE)_v12.0.0.39 Beta.exe"
0001
0002
0004
0005 00000018
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_39.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_39_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_39_ActiveX.dll
0012
0013
0015
0016
0017
=X====== M/12.0.0.39 2013-12-29+16-50-13.993 ========
=O====== M/12.0.0.39 2013-12-29+16-51-12.309 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\XIQJZ62K\Adobe_Flash_Player_(Non_IE)_v12.0.0.39 Beta.exe"
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_12_0_0_39.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_39_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_12_0_0_39.exe
0016
0017
0019
0020
0021
=X====== M/12.0.0.39 2013-12-29+16-51-51.518 ========
2014-1-15+8-29-14.362 [error] 1226 1062
=O====== M/12.0.0.47 2014-01-15+08-29-05.689 ========
0001
0002 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0003
0004 00000018
0005
0006
0007
0008
0009
0010 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_47.ocx
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_47_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_47_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/12.0.0.47 2014-01-15+08-29-17.617 ========
2014-1-15+9-29-16.840 [error] 1226 1062
=O====== M/12.0.0.47 2014-01-15+09-29-06.579 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_12_0_0_47.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_47_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_12_0_0_47.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/12.0.0.47 2014-01-15+09-29-18.610 ========
2014-1-22+16-29-21.448 [error] 1226 1062
=O====== M/12.0.0.54 2014-01-22+16-29-07.276 ========
0001
0003
0004 00000018
0005
0006
0007
0008
0009
0010 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_54.ocx
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_54_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_54_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/12.0.0.54 2014-01-22+16-29-26.325 ========
2014-1-22+17-29-22.793 [error] 1226 1062
=O====== M/12.0.0.54 2014-01-22+17-29-08.095 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_12_0_0_54.dll
0015 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_54_Plugin.exe
0016 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0017 00000017 C:\Windows\system32\Macromed\Flash
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_12_0_0_54.exe
0019 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0020
0021
0022 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0023
0024
0025
0026 00000012
=X====== M/12.0.0.54 2014-01-22+17-29-26.272 ========
2014-1-28+23-29-22.659 [error] 1226 1062
=O====== M/13.0.0.80 2014-01-28+23-29-09.005 ========
0001
0003
0004 00000018
0005
0006
0007
0008
0009
0010 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_80.ocx
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_80_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_80_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/13.0.0.80 2014-01-28+23-29-27.816 ========
2014-1-29+0-29-16.925 [error] 1226 1062
=O====== M/13.0.0.80 2014-01-29+00-29-08.049 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_13_0_0_80.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_80_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_13_0_0_80.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/13.0.0.80 2014-01-29+00-29-19.015 ========
2014-2-1+17-29-0.800 [error] 1221 1115
2014-2-21+0-29-18.800 [error] 1226 1062
=O====== M/13.0.0.130 2014-02-21+00-29-09.579 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_130.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_130_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_130_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/13.0.0.130 2014-02-21+00-29-22.887 ========
2014-2-21+1-29-14.502 [error] 1226 1062
=O====== M/13.0.0.130 2014-02-21+01-29-05.775 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_13_0_0_130.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_130_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_13_0_0_130.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/13.0.0.130 2014-02-21+01-29-16.591 ========
2014-2-26+7-30-2.515 [error] 1226 1062
=O====== M/13.0.0.133 2014-02-26+07-29-49.460 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009
0010 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_133.ocx
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_133_ActiveX.exe
0012 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_133_ActiveX.dll
0015
0016
0018
0019
0020
0021 00000012
=X====== M/13.0.0.133 2014-02-26+07-30-10.172 ========
2014-2-26+8-29-47.131 [error] 1226 1062
=O====== M/13.0.0.133 2014-02-26+08-29-37.607 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_13_0_0_133.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_133_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_13_0_0_133.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/13.0.0.133 2014-02-26+08-29-51.784 ========
2014-3-7+17-29-20.831 [error] 1226 1062
=O====== M/13.0.0.154 2014-03-07+17-29-07.607 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_154.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_154_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_154_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/13.0.0.154 2014-03-07+17-29-25.821 ========
2014-3-7+18-29-27.367 [error] 1226 1062
=O====== M/13.0.0.154 2014-03-07+18-29-12.141 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_13_0_0_154.dll
0015 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_154_Plugin.exe
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_13_0_0_154.exe
0020
0021
0023
0024
0025
0026 00000012
=X====== M/13.0.0.154 2014-03-07+18-29-30.862 ========
2014-3-11+23-29-17.385 [error] 1226 1062
=O====== M/13.0.0.162 2014-03-11+23-29-07.891 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_162.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_162_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_162_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/13.0.0.162 2014-03-11+23-29-22.132 ========
2014-3-12+0-29-15.129 [error] 1226 1062
=O====== M/13.0.0.162 2014-03-12+00-29-08.360 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_13_0_0_162.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_162_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_13_0_0_162.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/13.0.0.162 2014-03-12+00-29-16.981 ========
=O====== M/13.0.0.168 2014-03-19+07-29-13.229 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_168_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/13.0.0.168 2014-03-19+07-29-13.514 ========
2014-3-19+7-29-14.619 [error] 1226 1062
=O====== M/13.0.0.168 2014-03-19+07-29-06.110 ========
0002
0003 00000018
0004
0005
0006
0007
0008
0009 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_168.ocx
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_168_ActiveX.exe
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_168_ActiveX.dll
0014
0015
0017
0018
0019
0020 00000012
=X====== M/13.0.0.168 2014-03-19+07-29-17.833 ========
2014-3-19+8-29-14.272 [error] 1226 1062
=O====== M/13.0.0.168 2014-03-19+08-29-06.887 ========
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_13_0_0_168.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_168_Plugin.exe
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_13_0_0_168.exe
0016
0017
0019
0020
0021
0022 00000012
=X====== M/13.0.0.168 2014-03-19+08-29-16.531 ========
=O====== M/12.0.0.77 2014-03-20+20-34-58.573 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{60FA7263-4532-44AA-AAC8-6ED954BDB20F}\InstallFlashPlayer.exe" -iv 6
0001
0002
0004
0005 00000018
0006
0007
0008
0009
0010
0011 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_77.ocx
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0013 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0016
0017
0019
0020
0021
0022 00000012
=X====== M/12.0.0.77 2014-03-20+20-36-09.120 ========
=O====== M/12.0.0.77 2014-03-20+20-34-49.424 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-03-20+20-36-09.435 ========
=O====== M/12.0.0.77 2014-03-20+20-50-39.082 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{7C547A04-AAA7-4D0E-BCEF-7D04C027C311}\InstallFlashPlayer.exe" -iv 6
0002
0003
0004
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_77.ocx
0008
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0010
0011 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0012
0015
0016
0018
0019
0020
0021 00000012
=X====== M/12.0.0.77 2014-03-20+21-11-10.673 ========
=O====== M/12.0.0.77 2014-03-20+20-50-26.710 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-03-20+21-11-10.747 ========
=O====== M/12.0.0.77 2014-03-24+02-09-28.450 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{FFF59D5C-DD4E-4140-84BD-39E07EFC1847}\InstallFlashPlayer.exe" -iv 6
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_77.ocx
0003
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0005
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0007
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010
0011
0013
0014
0015
0016 00000012
=X====== M/12.0.0.77 2014-03-24+02-11-27.103 ========
=O====== M/12.0.0.77 2014-03-24+02-08-54.113 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-03-24+02-11-27.213 ========
=O====== M/12.0.0.77 2014-03-24+17-52-07.310 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{84EF2678-B442-4B7B-83AD-BF943C4D558C}\InstallFlashPlayer.exe" -iv 6
=X====== M/12.0.0.77 2014-03-24+17-52-19.937 ========
=O====== M/12.0.0.77 2014-03-24+17-51-58.254 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-03-24+17-52-20.006 ========
=O====== M/12.0.0.77 2014-03-24+18-19-58.258 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-03-24+18-50-08.588 ========
=O====== M/12.0.0.77 2014-03-24+18-20-08.664 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{D0890034-65C9-42B4-BACB-D68A2634B451}\InstallFlashPlayer.exe" -iv 6
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0007
0008
0010
0011
0012
0013 00000012
=X====== M/12.0.0.77 2014-03-24+19-01-12.810 ========
=O====== M/12.0.0.77 2014-03-28+22-27-54.224 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{6029CA1D-17D1-44D9-908B-4A15F5A657CE}\InstallFlashPlayer.exe" -iv 6
=X====== M/12.0.0.77 2014-03-28+22-28-15.611 ========
=O====== M/12.0.0.77 2014-03-28+22-27-37.536 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-03-28+22-28-16.102 ========
=O====== M/12.0.0.77 2014-04-01+13-42-16.866 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\{45F3314D-CB2B-4AB9-BEB7-004DC3D18FEA}\InstallFlashPlayer.exe" -iv 6
=X====== M/12.0.0.77 2014-04-01+13-44-35.780 ========
=O====== M/12.0.0.77 2014-04-01+13-41-55.863 ========
0001 00000011 1
=X====== M/12.0.0.77 2014-04-01+13-44-36.810 ========
=O====== M/13.0.0.182 2014-04-16+05-54-04.115 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Adobe\AIH.3a379dc4a2b1ebf611a95d51a3ccc82a61d30bbf\install_flash_player_ax.exe" -install -iv 10
0001
=X====== M/13.0.0.182 2014-04-16+05-54-06.040 ========
=O====== M/13.0.0.182 2014-04-23+13-23-47.469 ========
0001
=X====== M/13.0.0.182 2014-04-23+13-23-49.318 ========
=O====== M/13.0.0.182 2014-04-23+13-29-39.487 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Temp\InstallAX_13_0_0_182.exe" -install -msi
0001
=X====== M/13.0.0.182 2014-04-23+13-29-41.374 ========
=O====== M/13.0.0.182 2014-04-24+06-48-39.954 ========
0000 00000010 "C:\Users\sdbarker\AppData\Local\Adobe\AIH.677a46b1e3d9f18b0c526ae3a131a4fceb93443c\install_flash_player_ax.exe" -install -iv 8
0001
=X====== M/13.0.0.182 2014-04-24+06-48-41.972 ========
=O====== M/13.0.0.182 2014-04-24+06-58-05.081 ========
0001
=X====== M/13.0.0.182 2014-04-24+06-58-06.815 ========
