coldfusion builder2 not minimize(collapse) block of code proper way
Apr 22, 2014 Apr 22, 2014
Like for this code collapse not work properly:
<!DOCTYPE html>
<html>
          <head>
                         <meta http-equiv="Content-Type" content="text/html"; charset="utf-8"/>
        <title>
                                        Untitled Document
                         </title>
  </head>
          <body>
                         <div class="container body-content">
                                        <div class="row Heading">
                                                       <div class="col-md-12 ">
        <h3>
        Product Search
        </h3>
                                                       </div>
                                        </div>
            <div id="ProgressIndicator">
                                                  <div>
                                                  </div>
                                                  <!-- this will do the vertical align -->
                                                  <img alt="Loading.." src="Images/loading.gif"/>
                                   </div>
        <div class="row">
                                                  <div class="col-md-3 columnleft">
        <div class="row">
        <div class="col-md-12">
        <h6>
        RESULTS :
        <select id="resultRange">
        <option value="100">
        100
        </option>
        <option value="200">
        200
        </option>
        <option value="500">
        500
        </option>
        <option value="1000">
        1000
        </option>
        <option value="2000">
        2000
        </option>
        <option value="3000">
        3000
        </option>
        <option value="4000">
        4000
        </option>
        <option value="5000">
        5000
        </option>
        </select>
        </h6>
                                                            </div>
                                                  </div>
                                        </div>
                              </div>
                    </div>
          </body>
</html>
607
Adobe Employee , May 01, 2014 May 01, 2014
Moreover, I tried your code snippet. If you look at the below screen shot, the code collapses properly.
And its not collapsing the code below that. If you close a parent tag, then the sub tags will also close.
Anit Kumar
Guide ,
Screenshot of the problem? Or are you talking about the indenting being off?
-Carl V.
In this screen shot you can see that blcok of div not collapse proper way...When i try to minimize div block then all the code after that div minimize.
Guide ,
Apr 24, 2014 Apr 24, 2014
I'm not seeing anything obviously wrong with that code.  That said, the Aptana plugin used by CFBuilder 2 has always been a bit "dodgy".  If you can, try downloading the beta version of CFBuilder 3 ( http://www.adobe.com/cfusion/entitlement/index.cfm?e=labs_coldfusion11 ) and try it out.  They ripped out Aptana and rewrote the HTML-handling parts.  It's much faster and seems much more reliable.
-Carl V.
Apr 25, 2014 Apr 25, 2014
I know nothing is wrong in this code...All code is right but i think you dont understand my issue..My issue is when i collapse(minimize) any div block ya any other tag like <flayout> then collapse whole code after that div tag...form that div tag to HTML tag..
Guide ,
@Shraddha,
I only mentioned the code looking OK because I've had issues with code collapse when there were syntax issues with opening/closing tags.  So I was ruling that out as your issue.
Again, what you are seeing might just be a problem with the Aptana plugin that CFBuilder 2 uses.  Adobe bootstrapped HTML/JS/CSS/CFML code formatting and syntax highlighting support by leveraging Aptana in CFB1 & CFB2.  Adobe ditched Aptana and completely rewrote the HTML/JS/CSS/CFML stuff for CFB3, which is why I suggested downloading the beta and trying it out - that would confirm if you indeed are seeing a "bug" in CFBuilder that has been resolved in CFB3.
-Carl V.
Adobe Employee ,
@Shraddha,
Can you try CFB3 as suggested by Carl V and see, if you are still getting the code "collapse issue" or not?
Anit Kumar
No i dont try...I dont want to beta version of CFB3
Guide ,
Shraddha,
Since my post on April 25th, Adobe has released the actual ColdFusion Builder version 3 (not beta).  Download the trial version and see if the problems are fixed.  If they are, then you can decide whether to buy the CFBuilder upgrade.
-Carl V.
Adobe Employee ,
Anit Kumar
May 04, 2014 May 04, 2014
Ok Thanks...
Documentation
