How do you line up number when using NumberFormat function.
ie. The following code displays a positive and a negative
number that are both right justified:
xx33,456
(33,456)
(note: xx is used to demostrate spaces here, it does not show
up in the output)
<tr><td
align="right">#NumberFormat(33456,"(9,999)"
)#</td></tr>
<tr><td
align="right">#NumberFormat(-33456,"(9,999)"
)#</td></tr>
As you can see both lines or numbers are flushed to the right
and the numbers don't line up.
I need to have the numbers line up as follows:
x33,456
(33,456)
(again I used x as space here)
I can not use an extra space since the width of space is
different than ')'
I tried adding "<font color=white>)</font>" ie. a
white ')' at the end of positive numbers but that does not work
either.
Any suggestions?
Thank you in advance.
ArtSooki@aol.com
