The title of this post is self-explanatory. The pod just simply will not open. All my filters are checked in the Project Manager pod - don't know if that makes a difference in this case though. Something I'm doing wrong, or not doing?
I can see it now! Although, I don't think it was the fix provided in the link you sent Peter that fixed it. I did the steps suggested and no go. I then stumbled upon this thread by you at http://forums.adobe.com/message/4502519 where you fixed the problem, and after trying out the fix - out of the blue, I see my Topic List pod in the upper left corner of the screen as small as an icon. As soon as I maximized that, it was back! Perhaps it was a combination of the two fixes, but when I did the ste
...Copy link to clipboard
Try a Workspace/Environment reset?
Jeff, I reinstalled both RH 9 and RH Source Control -- problem is still not fixed. Any other suggestions? That Topic List pod was real helpful.
What happens if you open the sample projects?
Still doesn't work.
Maybe you need to post a screenshot of what you’re getting with the sample project. Use the camera icon in the web interface.
I get nothing - no activity whatsoever. I can open up all the other pods just fine. Of course the one I need the most...can't open. LOL. I don't mind posting a screenshot if you feel it'd be helpful.
Have you been using dual screens?
http://cybertext.wordpress.com/2008/04/07/lost-your-windows/
I can see it now! Although, I don't think it was the fix provided in the link you sent Peter that fixed it. I did the steps suggested and no go. I then stumbled upon this thread by you at http://forums.adobe.com/message/4502519 where you fixed the problem, and after trying out the fix - out of the blue, I see my Topic List pod in the upper left corner of the screen as small as an icon. As soon as I maximized that, it was back! Perhaps it was a combination of the two fixes, but when I did the steps in the suggestion above, it would only show the programs, not apps/windows/pods within the program. Regardless, I'm back in business. Thank you Jeff and Peter for your expertise on this - I appreciate it!
Didn’t I suggest resetting the workspace back in my first post to you?
I thought you meant to re-install RH. I wasn't aware of that menu option until Peter mentioned where it was located in the post.
