I have installed CF10 on an Amazon AWS Windows 2012 instance. No matter what I use for the admin console password during setup, the password is not recognized when setup is complete and I try to log into the admin console. I've uninstalled and reinstalled four times trying simple as well as complex password with no luck.
I am having the same issue except on our own Win2012R2 server. I have tried all of the suggestions I have found online with out any luck so far.
Try to login from your machine rather than server itself with different browsers.
Also, run the passwordreset.bat(C:\ColdFusion10\cfusion\bin) and try to change the password. Then login.
HTH
VJ
Hi Vishu,
I have done both of your suggestions without any luck.
Pete
Good advice! Interestingly, I can login remotely but not on the local machine. Why is that? How do I fix it?
Please share the request/response header
