1. Re: adobe premiere elements 12 probleme douverture du programme
John T Smith Apr 30, 2014 4:28 PM (in response to ocho 3546)From the Premiere Elements Information FAQ http://forums.adobe.com/thread/1042180
•Have you checked for a program update?
•What operating system? This should include specific minor version numbers, like "Mac OSX v10.6.8"---not just "Mac"
•Has this ever worked before? If so, do you recall any changes you made to Premiere Elements, such as adding Plug-ins, brushes, etc.? Did you make any changes to your system, such as updating hardware, printers or drivers; or installing/uninstalling any programs?
•Are you using an account with Administrator Privileges?
Run as Administrator http://forums.adobe.com/thread/969395 (Encore + "All" Premiere)
•Have you installed any recent program or OS updates? (If not, you should. They fix a lot of problems.)
•What kind(s) of image file(s)? When talking about camera raw files, include the model of camera.
•If you are getting error message(s), what is the full text of the error message(s)?
•What were you doing when the problem occurred?
•What other software are you running?
•Tell us about your computer hardware. How much RAM is installed? How much free space is on your system (C:) drive?
And some other questions...
•What are you editing, and does your video have a red line over it BEFORE you do any work?
•Which version of Quicktime do you have installed?
What is your exact brand/model graphics adapter (ATI or nVidia or ???)
What is your exact graphics adapter driver version?
Have you gone to the vendor web site to check for a newer driver?
For Windows, do NOT rely on Windows Update to have current driver information
-you need to go direct to the vendor web site and check updates for yourself
ATI Driver Autodetect http://support.amd.com/en-us/download/auto-detect-tool
nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
2. Re: adobe premiere elements 12 probleme douverture du programme
A.T. Romano Apr 30, 2014 4:35 PM (in response to ocho 3546)ocho 3546
Both the Translate button here (French to English) and Google Translate are having problems with what you wrote in French.
Could you please write again in English or with another description in French.
I am understanding that you have Premiere Elements 12. What computer operating system is your Premiere Elements 12 running on?
Are you having problems opening the program from the desktop icon? Or, are you having problems opening a pre-existing project? Can you open a new project? What errors messages, if any, are associated with your Premiere Elements problems.
Please give as much detail as possible.
Thank you.
ATR
3. Re: adobe premiere elements 12 probleme douverture du programme
A.T. Romano Apr 30, 2014 8:45 PM (in response to ocho 3546)ocho 3546
Thank you for posting a re-written thread since this one that we are in now was difficult to understand.
Your new thread can be found
http://forums.adobe.com/thread/1462947?tstart=0
I am suggesting that we continue in the other thread, not the one that we are in now.
Thank you.
ATR
4. Re: adobe premiere elements 12 probleme douverture du programme
ocho 3546 May 3, 2014 10:25 PM (in response to A.T. Romano)J'ai une carte graphique très récente pc neuf Monté par non électronicien DOI-je faire une Mise à jour des Pilotes
Intel (R) HD Graphics 4600
5. Re: adobe premiere elements 12 probleme douverture du programme
A.T. Romano May 4, 2014 8:12 AM (in response to ocho 3546)ocho3546
Thank you for the reply.
From what you have written so far, I am understanding you are having a problem opening the program. It is not clear whether you are saying opening the program or opening a project.
Let us proceed with the program not opening (launching).
a. You say that you have latest driver for the HD Graphics 4600. Please make sure that the drive update information is from the web site of the manufacturer of the card, not just from Device Manager/Display Adapters/your card and the Driver Tab. If the card is up to date, then try to delete the BadDrivers.txt file. If you are using Windows 7, 8, or 8.1 64 bit computer, then the BadDrivers.txt file is found
Local Disk C
Program Data
Adobe
Premiere Elements
and in the Premiere Elements Folder is the BadDrivers.txt file that you delete. The Premiere Elements Folder contains folders as well as the BadDrivers.txt file. You want only the BadDrivers.txt file within the Premiere Elements Folder and not anything in the folders in that same Premiere Elements Folder. A new BadDrivers.txt file will be generated when you open a Premiere Elements project and the problem hopefully will be gone. Be sure to be working with Folder Option Show Hidden Files, Folders, and Drives active so that you can see the complete path cited.
b. Be sure to be working Run As Administrator and from a User Account with Administrative Privileges.
c. What antivirus program does your computer use? Please determine if the program exists with and without the antivirus program disabled.
d. Be sure to have the latest version of QuickTime installed on your computer.
e. If the above has not solved the problem, then let us delete the Adobe Premiere Elements Prefs file. The path in Windows 7, 8, or 8.1 64 bit is
Local Disk C
Users
Owner
AppData
Roaming
Adobe
Premiere Elements
12.0
and, in the 12.0 Folder is the Adobe Premiere Elements Prefs file that you delete. If that does not work then you delete the whole 12.0 Folder in which it exists.
f. Do the uninstall, ccleaner run through, reinstall with antivirus and firewalls turned off.
CCleaner - PC Optimization and Cleaning - Free Download
The translations are not good and the details limited so I am including a lot of troubleshooting possibilities to cover a lot of ground.
Other avenues that might be involved
ATR Premiere Elements Troubleshooting: PE12: Premiere Elements 12 Editor Will Not Open
Please review and consider.
Thank you.
ATR
