2 Replies Latest reply: May 1, 2014 2:15 PM by James22s22 RSS
    Converting AS2 to AS3 and running into errors
    melaniesamazing Community Member
      I am working on a project for work and I don't have anyone to go to with this issue that would actually know. I am currently converting a clients file from AS2 to AS3 in order to run in our specific platform and template. I have gotten pretty far but I am stuck here. I am getting an "Error 1152: A conflict exists with inherited definition flash.display.MovieClip.currentLabel in namespace public. (referring to "var currentLabel:Number = 0;" And if you see any other errors below please let me know! Thank you so much for your help and time in advance. I can use anything I can get!
      var labelArr:Array = ["un","deux","trois","quatre"];
      function NEXT(event:MouseEvent):void
           if (currentLabel < labelArr.length - 1) {
              currentLabel++;
              gotoAndPlay(labelArr[currentLabel]);
          else{
              //whatever you want .. like jump back to the the beginning
              currentLabel = 0;
      next_btn.addEventListener(MouseEvent.CLICK, NEXT);
      function PREV(event:MouseEvent):void
           if (currentLabel > 0) {
              currentLabel--;
          else{
              //whatever you want .. like jump to the end.
              currentLabel = labelArr.length - 1;
      prev_btn.addEventListener(MouseEvent.CLICK, PREV);
        • 1. Re: Converting AS2 to AS3 and running into errors
          Ned Murphy CommunityMVP
          You can probably just rename that variable to something else to solve the error issue.  AS3 has a currentLabel property for the MovieClip class, so anything with a timeline essentially has that proiperty.  IF you rename it to something else the error should go away.
          • 2. Re: Converting AS2 to AS3 and running into errors
            James22s22 Community Member
            In addition to the currentLabel property, the AS3 MovieClip class already keeps an Array of all timeline labels for you in the currentLabels property:
            http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/display/MovieClip .html#currentLabels
            Each item in the array is of type flash.display.FrameLabel, which has properties frame:int and name:String.
            The code could be updated and reduced to this:
            import flash.display.FrameLabel;
                for (var i:int = 0; i < currentLabels.length; i++) //get index of current label by matching current label name
                    if ((currentLabels[i] as FrameLabel).name == currentLabel)
                        break;
                if (i < currentLabels.length - 1)
                    gotoAndPlay((currentLabels[i+1] as FrameLabel).frame)
                else //whatever you want .. like jump back to the the beginning
                    gotoAndPlay((currentLabels[0] as FrameLabel).frame)
                        break;
                if (i > 0)
                    gotoAndPlay((currentLabels[i-1] as FrameLabel).frame)
                else //whatever you want .. like jump to the end.
                    gotoAndPlay((currentLabels[currentLabels.length - 1] as FrameLabel).frame)
            Also worthy of mention is the difference between the currentLabel and currentFrameLabel properties, which are slightly different.  I've paraphrased/corrected the documentation to clarify it.
            currentFrameLabel: The label, if one is present, on exactly the current frame.  If the current frame has no label, currentFrameLabel is null.
            vs
            currentLabel: The label, if one is present, on exactly the current frame OR, if one is not present on the current frame, the next earlier frame that happens to include a label.  currentLabel returns null only if neither the current nor any previous frames include a label.
            More than likely, you want to use currentLabel to avoid null values when the playhead is on an unlabeled frame between your labeled frames.
