DataTable in Coldfusion (in cfscript)
Apr 29, 2014 Apr 29, 2014
Hi i want to add DataTable in Coldfusion script...Like c# code...C# code is following:
                   DataTable productPropertyFilterTable = new DataTable();
                    productPropertyFilterTable.Columns.Add("RowID", typeof(int));
                    productPropertyFilterTable.Columns.Add("PropertyId", typeof(long));
                    productPropertyFilterTable.Columns.Add("PropertyWeight", typeof(string));
                    productPropertyFilterTable.Columns.Add("LowerRange", typeof(float));
                    productPropertyFilterTable.Columns.Add("UpperRange", typeof(float));
961
Engaged , Apr 30, 2014 Apr 30, 2014
You want to use QueryNew and QueryAddColumn.
productPropertyFilterTable  = queryNew('');
queryAddColumn(productPropertyFilterTable, 'RowID', 'Integer');
queryAddColumn(productPropertyFilterTable, 'PropertyWeight', 'VarChar');
Alternatively you can just do the same with QueryNew on its own.
productPropertyFilterTable  = queryNew('RowID,PropertyWeight', 'Integer,VarChar');
Engaged ,
May 01, 2014 May 01, 2014
How to add data in datatabel like C# Code:
productPropertyFilterTable.Rows.Add(i, wordsStrings[0], wordsStrings[3], Limit[0], Limit[1]);
Engaged ,
Now you need to use QueryAddRow and QuerySetCell
I try to use
queryAddRow(productPropertyFilterTable,1);
querySetCell(productPropertyFilterTable,RowID,i,1);
but its not work....
Engaged ,
That second line you need to quote the column name:
querySetCell(productPropertyFilterTable, "RowID", i, 1);
Thanks...Its work....
Hi i have another issue...How can i write this c# code in coldfusion(Script).....
var warnings = new SqlParameter("ProductPropertyFilter", SqlDbType.Structured);
                        warnings.Value = productPropertyFilterTable;
                        warnings.TypeName = @"[dbo].[ProductPropertyFilter]";
                        using (var ctx = new ProductBookEntities())
                            var productFilter = ctx.Database.SqlQuery<ProductFilter>("dbo.FindScore @ProductPropertyFilter",
                               warnings);
                            dataProducts = productFilter.ToList();
                            if (dataProducts.Count() > range)
                                dataProducts = dataProducts.OrderByDescending(x => x.Score).Take(range).ToList();
                            ctx.Dispose();
Engaged ,
You probably want to start by reading up on some CF documentation of how to do queries.  Start here:
remote function Retrieve(string dataLists)
myQry = new Query();
myQry.setSQL("SELECT * FROM Product");
myQuery = myQry.execute();
dataProducts=myQuery.getResult();
dataProducts1=serializeJSON(dataProducts);
return dataProducts;
I call this method by using following code::
read: {
          type:"POST",
         url: "Controllers/Home.cfc",
         dataType: "json",
         data: {
                 method: "Retrieve",
                 dataLists: JSON.stringify(request)
I want to return dataProducts or dataProducts1 from function , i want to know that which type of data they return string or list or json??
And also we get (dataProducts1=null), why this happen???In dataProducts i get the value...when i convert it json i get null value.....why????
Documentation
