ColdFusion 11: <cfclient> seems to require /CFIDE to be available
Adam Cameron. May 3, 2014 8:43 AMG'day:
I am reposting this from my blog ("ColdFusion 11: <cfclient> seems to require /CFIDE to be available") at the suggestion of Adobe support:
@dacCfml @ColdFusion Can you post your queries at http://t.co/8UF4uCajTC for all cfclient and mobile queries.
— Anit Kumar Panda (@anitkumar85) April 29, 2014
I have edited this in places to remove language that will be deemed inappropriate by the censors here. Changes I have made are in [square brackets]. The forums software here has broken some of the styling, but so be it.
G'day:
This will be a short one... I just want to trot out various observations I make about <cfclient> as I make them. I don't want to waste too much effort on it.
I also feel a bit dirty round about now... I'm about to use a <cfform> tag.
As should everyone, I do not expose /CFIDE to the outside world. This is a terrible vector for security vulnerabilities. One that Adobe seems to be dragging its heels about resolving once and for all ("Isolate the /CFIDE/scripts directory from the rest of /CFIDE" (3732913)).
So when I'm using <cfform> (which is only ever when I am writing example code like this), I need to redirect ColdFusion to look in my isolated directory which just has the script stuff in it:
<cfajaximport scriptsrc="/lib/js/CF/scripts"> <cfform method="post" action="#CGI.script_name#"> <cfinput type="dateField" name="date"> <input type="submit" name="submitButton" value="Go"> </cfform> <cfdump var="#form#">
Note: do not use <cfform> or any of ColdFusion's other UI wizard tags. Just don't. See here: "ColdFusion UI the Right Way", here: "I'm not going to tell you to stop using ColdFusion UI tags anymore...", and here: "Oi! You [naughty] [people]! Stop using ColdFusion UI controls".
Anyway, back to the code. The poorly-named <cfajaximport> tag allows one to point ColdFusion at a different, isolated directory. That's quite handy.
Now I try it with my <cfclient> code:
<cfajaximport scriptsrc="/lib/js/CF/scripts"> <cfclient> <cfset message = "G'day World"> <cfoutput>#message#</cfoutput> </cfclient>
and I get this:
| 14:46:11.292 | GET | http://localhost:8511 /shared/scratch/blogExamples/coldfusion /CF11/cfclient/moveScriptDir.cfm | [HTTP/1.1 200 OK 284ms] |
| 14:46:11.655 | GET | http://localhost:8511 /lib/js/CF/scripts/ajax/messages/cfmessage.js | [HTTP/1.1 200 OK 5ms] |
| 14:46:11.655 | GET | http://localhost:8511 /lib/js/CF/scripts/ajax/package/cfajax.js | [HTTP/1.1 200 OK 10ms] |
| 14:46:11.656 | GET | http://localhost:8511/CFIDE/cfclient/cfclient_main.js | [HTTP/1.1 404 /CFIDE/cfclient/cfclient_main.js 3ms] |
| 14:46:11.656 | GET | http://localhost:8511/CFIDE/cfclient/cffunctions.js | [HTTP/1.1 404 /CFIDE/cfclient/cffunctions.js 3ms] |
| 14:46:11.657 | GET | http://localhost:8511/CFIDE/cfclient/cfclient_main.js | [HTTP/1.1 404 /CFIDE/cfclient/cfclient_main.js 1ms] |
| 14:46:11.657 | GET | http://localhost:8511/CFIDE/cfclient/cffunctions.js | [HTTP/1.1 404 /CFIDE/cfclient/cffunctions.js 0ms] |
Groan. Because <cfclient> doesn't put its script files in the scripts dir, does it? No. Of course it doesn't. Muppets.
But this could still be solved if one could specify some other way of pointing it to a different location for its resources, but... no. There's not a way of doing this that I can find. Short of [messing] around on the web server and setting up virtual directories pointing to /CFIDE/cfclient. This isn't really a hardship, but still, it just shouldn't be necessary, and I can't help but think this is a bit sloppy on the part of Adobe.
It also demonstrates that for their internal testing they don't test this sort of thing. Which is odd, as it's the second thing I tested: you know, that it even works on a secured server.
That's it. I've nothing else to say on this topic. I'll raise a bug for this shortly, once I have the article published so I can refer back to it: 3750729.
Adam
