Error when looping over list
Jun 16, 2007 Jun 16, 2007
Looping over a series of lists created from form fields generates an error when one of the fields on the form has been left blank. The form is a list of event dates, start times and end times. One event can have a number of times.
When the end time is uncertain, we want to leave it blank. However, doing so shortens the list created from #form.endtime# so that the lists don't match and there's an error message:
"Invalid list index 2.
In function ListGetAt(list, index [, delimiters]), the value of index, 2, is not a valid as the first argument (this list has 1 elements). Valid indexes are in the range 1 through the number of elements in the list."
How do you get around this problem? Tx.
Advanced techniques
645
Guide , Jun 16, 2007 Jun 16, 2007
yoman,
No need for separate forms. Use a counter to number each group of field names
<input name="EventDateID1" ...>
<input name="EventDate1" ...>
<input name="EventDateID2" ...>
<input name="EventDate2" ...>
Then loop through the form fields on your action page
<cfloop from="1" to="#form.maxCounter#" index="counter">
<cfset EventDateID = form["EventDateID#counter#">
<cfset EventDate = form["EventDate#counter#">
... rest of fields
<cfquery name="UpdateFeatures" datasource="#dsn#">
UPD...
Participant ,
<cfparam> Set a default value if none is passed.
I understand what you're getting at, but where would I put the cfparam? The form is like the attached. So, if there are two event dates, but only one end time, a simplified version of the lists look like this:
FORM.Event_ID = 200, 200 = TheEvent_ID
FORM.eventDatesID = 365, 366 = List_EventIDs
FORM.endTime = 4:30 = ListOfEndTimes
So, when the loop happens, there is no #ListGetAt(ListEndOfTimes,2)# the second time through and there's an error.
Maybe my basic concept is wrong. Where would I put the cfparam?
Participant ,
Ok, I thought you had empty lists being passed by the form action. So <cfparam> might have helped you there.
This code I'm pretty sure works, I seem to remember reading that you can loop through scope variables like arrays, so that FORM[index] works like...
That would make all lists the same length, but I don't think it would put the correct values at the right point in the list. Would it?
Say the 2nd item lacked an end time. The code would pad the list to create this:
EventDateID = 1, 2, 3
EndTime = 11pm, 11pm, (Empty)
But I need the end times to correspond with the EventDateIDs:
EndTime = 11pm, (Empty),11pm
I know the problem can be resolved by making each row of fields be a form, processing the one that needs to be updated and then starting over, but that seems annoyingly inefficient.
Tx.
Guide ,
yoman,
... rest of fields
UPDATE EventDates
SET EventDate = '#EventDate#', ....
WHERE EventDateID = #EventDateID#
</cfquery>
</cfloop>
You should validate the values and/or use cfqueryparam
Sounds like it will work. Thanks. I'll try it Monday when my brain has recovered enough. 😉
Guide ,
Jun 17, 2007 Jun 17, 2007
Close the square brackets in the real code of course ...
<cfset EventDateID = form["EventDateID#counter#"]>
<cfset EventDate = form["EventDate#counter#"]>
Documentation
