Had to revisit several projects that were working this past January, but now several are reporting as being 'corrupted'. After trying all of the usual recommended remedies, and failing, I attempted what is always my 'last resort' - Trashing Preferences. Last resort because it has always in recent versions, led to other problems. This time was no exception. Now, not only did trashing them NOT solve my corrupt project issue, but it added a couple more. Now, MB Looks plugin can't be seen, which has happened nearly every time I've trashed preferences, and certain .mts files are showing as being the dreaded 'Unsupported compression type', while many in the same folder are working just fine. This almost always seems to be a license issue of some sort. I have signed out of CC, then signed back in to no avail. My short term memory is nearly gone, but I seem to recall a similar set of occurrences a few months ago, and a uninstall/re-install was required to bring everything back to normal. This is getting quite old, as am I.
Working with Adobe Support via chat at the moment. Their solution? - Contact Red Giant.
