Hi
I am using TCS 4.0, RH10.
I am creating the ISF file, master page, skin, etc. for my team's use. While publishing to WebHelp, we always perform the following tasks in the WebHelp settings window for every project:
Is there a way I can configure these settings in some file and share it with the team (along with ISF files, etc.) so that they don't have to do it every time? I agree that selecting and deslecting few check boxes is not such a major time consuming task. However, I am curious if I can avoid manual intervention here.
Sreekanth
I have not tested but try copying the SSL file in the Project root folder from one machine to another.
Thanks for your quick reply Peter. That worked.
Sreekanth
Peter is right but I think you need to be careful about other files which refer to the SSL. For example projectname.pss and rhlayout.apj. However as long as everyone uses the same SSL names you will be OK.
Yes, everybody uses the same file.
Sreekanth
