Save and share WebHelp publish settings
Mentor ,
May 06, 2014 May 06, 2014
Hi
I am using TCS 4.0, RH10.
I am creating the ISF file, master page, skin, etc. for my team's use. While publishing to WebHelp, we always perform the following tasks in the WebHelp settings window for every project:
  1. In Content Categories > Content <default>, select Apply to all Topics and select the default master page (which is basically the only master page they have added).
  2. In Navigation, clear Search Input Field in Toolbar check box.
  3. In Search, select the Hide Rank Column in Search Results check box.
Is there a way I can configure these settings in some file and share it with the team (along with ISF files, etc.) so that they don't have to do it every time? I agree that selecting and deslecting few check boxes is not such a major time consuming task. However, I am curious if I can avoid manual intervention here.
Sreekanth
246
Community Expert , May 06, 2014 May 06, 2014
I have not tested but try copying the SSL file in the Project root folder from one machine to another.
@petergrainge
@petergrainge
Mentor ,
Thanks for your quick reply Peter. That worked.
Sreekanth
Peter is right but I think you need to be careful about other files which refer to the SSL. For example projectname.pss and rhlayout.apj. However as long as everyone uses the same SSL names you will be OK.
Mentor ,
Yes, everybody uses the same file.
Sreekanth
RoboHelp Documentation
Download Adobe RoboHelp
