Sorry, Peter, I came across as a bit pompous then, didn't I?
Not intentional, I wasn't thinking! This is the first time I have
actually REGISTERED! I can't believe that I have been here since
the eHelp days, and still haven't registered!
Anyway, enough grovelling......
I have narrowed down the problem to Build Tags. If I remove
the definitions from the WebHelp Pro wizard, it generates and
publishes just fine, albeit a bit slow. If you include the build
tags, it gets halfway through the generation process, slows to a
halt, the hard drive starts grindng and grinding and you have to
shut it down. Start RHelp6, remove the build definitions, and it's
fine.
I went through the project and deleted all the build tags.
Then I scoured each page for instances of "x-condition:" and
deleted these, too (I had some old build expressions that had been
created a couple of years ago still embedded in a couple of the
pages). I then created a new build tag and included it in the
process, and it crashed, same as before.
I have carried out the recommended "bug fix" (snippet 68,
thanks for that) but it had no effect.
We use build tags quite a lot in our projects. Did I mention
that all our other projects are just fine? It's just this one
project, which is the most important one (of course) and the
largest (114 Mb).
I think the next step is to try and isolate the particular
document that is causing us grief. Maybe creating a copy and
deleting folders until the problem goes away.
Any assistance would be greatly appreciated.
BTW, this project has evolved over the last 6 years, starting
as a huge bunch of FrontPage files (about 15,000 pages), migrated
into RHelp 3, then x5, DotNet upgrade/Rengine/Rsource and now
RHelp6/RServer6/RSource6. It is launched as On Line Help into a
large, distributed software application as context sensitve Help
served up from a dedicated Help Server that I administer. There are
two Tech Writers who collaborate on all projects that are in
RoboSource source control, again, on a server that I administer.
Thanks again!
