Password not accepted on new CF 11 installation migration wizard (enter.cfm)
May 06, 2014 May 06, 2014
Hi having an issue on the initial migration wizard page (enter.cfm) - it won't take my administrator password (reinstalled CF 3 times) and double sure I am typing the correct password - anybody else have similar issues?
CF11 clean install
Windows 2008R2
IIS7.5
5.0K
Community Beginner , Aug 28, 2014 Aug 28, 2014
I have just installed CF11 on a windows 2008 server and had the same issue. I was able to resolve it by adding http://127.0.0.1 to my list of local intranet sites in the internet options of the browser. I guess I could have changed the URL to be localhost as oppose to 127.0.0.1, but this worked for me. Hope it helps others.
Adobe Employee ,
Please try these steps, first try to reset the password using passwordreset.bat file which resides in C:\ColdFusion10\cfusion\bin\ after the restart the ColdFusion Application server service.
reduce the security in your IE browser (Local Intranet), try with a different browser or try to access the Admin from another machine.
Priyank
Priyank Shrivastava
Enthusiast ,
May 07, 2014 May 07, 2014
In addition to the above
Try to login from your machine rather than server itself with different browsers
Please share the request/response header (you can use free trail of Charles)
HTH
VJ
thank you both, unfortunately none of the above work, any more ideas greatly appreciated...
I have tried multiple passwords (both simple and complex) but this does not seem to make a difference
Jun 23, 2014 Jun 23, 2014
I'm experiencing the same thing. I even tried reinstalling with another password, and its not working at all. What the heck?
Enthusiast ,
Launch passwordreset.bat (C:\ColdFusion11\cfusion\bin) via command prompt (Run as Administrator)
Change the password to a simple password like  "your first name"
Then instead of the server itself, access the CF 11 administrator from your machine.
You will be able to login, once you are able to login then login to the server remotely and try from there.
You will be able to login within the server itself. Then you can change the password in "Administrator" under "security"
If the above did not work then please share the request/response header
HTH
VJ
VJ,
Running passwordreset.bat as Administrator gave me this message "Your Admin and RDS password has been reset. Re-start the server to reflect the changes." Running it with out Administrator privileges doesn't give me this message.
But I still can't login via my computer remotely or within the server itself.
Aug 18, 2014 Aug 18, 2014
Were you able to resolve this issue? I am having the same issue with clean install of cf 11. No matter if i change the PW with passwordreset.bat or reinstall CF, it always says "Invalid User name or Password. Please try again." I uninistalled and reinstalled CF 4 times.
CF11
WIndows 7 Enterprise
Enthusiast ,
Aug 19, 2014 Aug 19, 2014
I looked at everything that was mentioned in that blog, still no luck.
Sep 19, 2014 Sep 19, 2014
Having the same issue. Tried all suggestions above, tried reinstalling - no luck. Still getting Invalid Password. Please try again. everytime i try to configure server.
Found Solution
Go to your web.config file and comment out the following line
<!--<mimeMap fileExtension=".air" mimeType="application/vnd.adobe.air-application-installer-package zip" /> -->
Aug 16, 2016 Aug 16, 2016
Cesko45,
This also worked for me.  Thanks!
May 26, 2017 May 26, 2017
Thanks cesk045. Your solution worked for me too!  many thanks!
Aug 08, 2017 Aug 08, 2017
My problem was with IE Edge browser.  Switched to FireFox and was able to login.
Documentation
