QueryToJson
May 06, 2014 May 06, 2014
Hi i want to convert Query object into json data::
But i got this type record:
[{"PRODUCTNAME":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":1},{"PRODUCTNAME":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":2}]
And I wan  to this type record::
[{"ProductName":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","ProductCategoryId":1,"ProductId":1},{"ProductName":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","ProductCategoryId":1,"ProductId":2}]
I want Field name according to my Table Column Name...(Not all characters of columns are capital like above)
my code:
QueryToJson.cfm
<!DOCTYPE html>
<html>
  <body>
<cfscript>
  myJSON=new Component.queryTojson().queryToJSON();
</cfscript>
  <cfdump var="#myJSON#" >
  </body>
</html>
queryTojson.cfc
<cfcomponent>
<cffunction name="queryToJSON" returntype="string" access="public" output="yes">
  <cfquery name="getallproducts" datasource="TestingDataSource">
     SELECT TOP 2 * from Product;
    </cfquery>
  <cfset var o=ArrayNew(1)>
  <cfset var i=0>
  <cfset var r=0>
  <cfloop query="getallproducts">
    <cfset r=Currentrow>
    <cfloop index="i" list="#(getallproducts.columnList)#">
      <cfset o=Evaluate(i)>
    </cfloop>
  </cfloop>
    <cfreturn SerializeJSON(o)>
</cffunction>
</cfcomponent>
Product(Table)
ProductId
ProductCategoryId
ProductName
663
Community Expert , May 06, 2014 May 06, 2014
You could use replaceList() on the resulting JSON string. It does a case-sensitive replacement.
<cfsavecontent variable="jsonString">
</cfsavecontent>
<cfset list1="PRODUCTNAME,PRODUCTCATEGORYID,PRODUCTID,PRODUCTNAME">
<cfset list2="ProductName,ProductCategoryId,ProductId,Product
Advocate ,
Query column names and structure key names are capitalized in CF and I that is just something you have to deal with. There is one exception with structures that I am aware of:
     <cfset variables.s.FieldName="abc" />
will be capitalized when using StructKeyList() whereas
     <cfset variables.s["FieldName"]="abc" />
will preserve the upper/lower case. I'm not aware of any such exception with query column names.
If I have full control of the end using the json data, I send the column names through LCase() and just deal with lower case names. Other than that, the only other option is to create a hard coded field name translater: PRODUCTID--> ProductId.
Hope this helps.
</cfsavecontent>
<cfset list2="ProductName,ProductCategoryId,ProductId,ProductName">
<cfset newJsonString = replaceList(jsonString,list1,list2)>
<p><cfoutput>#newJsonString#</cfoutput></p>
Advocate ,
Hmmm. I've never used (or knew about) replaceList() -- learn something new everyday. I'll have to file that in my arsenal of tricks.
Only this way replaceList(), i can do this , Have you any other way???
May 07, 2014 May 07, 2014
Hi, i try to write queryTojson.cfc in script format:
component
  public string function queryToJSON() output="yes"
  q = new Query();
  q.setdataSource("TestingDataSource");
  q.setsql("SELECT * FROM Product");
  qResult = q.execute().getresult();
  o=ArrayNew(1);
  i=0;
  r=0;
  x=0;
  for(x=1;x LTE qResult.recordcount;x=x+1)
  r=qresult.Currentrow;
  var l = ListLen(qResult.Columnlist);
     for (i = 1; i lte l; i = i + 1)  // you also can use i++ instead
      o=Evaluate(i);
  jsonString = SerializeJSON(o);
  return jsonString;
But i got the output in this format:
[{"3":3,"2":2,"1":1}]
How to write queryTojson.cfc in script format??
You are getting that output because r remains fixed. The dynamic value of row number you should use in setting rows in o is x, not r. You could modify the code as follows:
var q = new Query();
var qResult = "";
var colList = "";
var l = 0;
var x = 0;
var i = 0;
var o=ArrayNew(1);
colList = qResult.Columnlist;
l = ListLen(colList);
for(x=1;x LTE qResult.recordcount;x=x+1) // x is row number
    columnName = listGetAt(colList,i);
    o=qResult[columnName];
return jsonString;
Anyway, why do you serialize an array representation of the result-set? You can just serialize the result-set itself directly, like this:
var qResult = "";
jsonString = SerializeJSON(qResult);
return jsonString;
Yet another suggestion: use a struct instead of an array. A struct would give more information, as it can hold the column name as key. Here is the struct version of your code:
var qResult = "";
var colList = "";
var l = 0;
var x = 0;
var i = 0;
var str=structNew();
    str[columnName]=qResult[columnName];
jsonString = SerializeJSON(str);
return jsonString;
Hi , Thanks for your reply....
Your 1St Method, i got this type output:
[{"3":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","2":1,"1":1},{"3":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","2":2,"1":1}]
And Your 2nd Method, i got this type output:
{"COLUMNS":["PRODUCTID","PRODUCTCATEGORYID","PRODUCTNAME"],"DATA":[[1,1,"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)"],[2,1,"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)"]]}
And your 3rd method struct version , in this i got following output:
{"2":{"PRODUCTNAME":"2014 Chevrolet Cruze Diesel 4dr Sedan (2.0L 4cyl Turbodiesel 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":2},"1":{"PRODUCTNAME":"2014 Kia Cadenza Premium 4dr Sedan (3.3L 6cyl 6A)","PRODUCTCATEGORYID":1,"PRODUCTID":1}}
But actually i want to get this type of json output, because its suit for kendo Model:
Have you any other script code to get this type of json Data, from Query object???
May 08, 2014 May 08, 2014
What you want is so close to the third result, it requires just a slight change in that code.
var qResult = "";
var colList = "";
var l = 0;
var x = 0;
var i = 0;
var arr=arrayNew(1);
    arr=str; // each row x is stored in the array arr as a struct
jsonString = SerializeJSON(arr);
return jsonString;
May 12, 2014 May 12, 2014
Thanks its work...
Documentation
