1. Re: screen resolution to set up photoshop file for edge reflow
gc234 Dec 10, 2013 10:48 AM (in response to gc234)i should add both my iphone is iphone 5(640x1136px) with the retina display.
one more thing to add:
or perhaps there's a way to tell edge inpect/reflow to account for the retina display??
thx
grace
2. Re: screen resolution to set up photoshop file for edge reflow
Seth Walker Dec 10, 2013 11:04 AM (in response to gc234)hello,
You are correct that viewport size does not equal screen size. The newer iphones I believe are 480px now, not 320px http://viewportsizes.com/?filter=iphone. But they are 144dpi I believe.
In photoshop, the designs you have may need some tweaking when you go from standard def to retina sizes. This is kind of strange, but alas, welcome to device fragmentation .
You can setup your export of those image based assets in PS with the new generator work flow. You can assign one-to-many values for export. It can come in handy when dealing with multiple dpi devices and designs in the same PSD. http://blogs.adobe.com/photoshopdotcom/2013/09/introducing-adobe-generator-for-photoshop-c c.html.
I would maybe say, choose one dpi in PS and know you may need to export several images to accomodate the change in dpi for different devices. Keep those things as smart objects! That's usually what I do to avoid image crappienes. Once in reflow, you can set BOX background images at your 1280px media query to a @1x image, and at the retina screen size of say 480px change it to @2x. You won't need any JS or additional logic to make it happen. You can't however, swap an image object in the same way, that would require some other kind of coding we don't yet support.
3. Re: screen resolution to set up photoshop file for edge reflow
gc234 Dec 10, 2013 11:31 AM (in response to Seth Walker)thanks for the quick reply.
if i'm going mobile first and designing for the narrowest screen, which is vertical , 320px
this means if i want to have 1:1 relationship btw font size specs. i need to set up my phosothop psd file at 320px width?? bc if i set up my psd file at retina resolution my font size will be double the size..ie. if the psd file is set up at retina resolution. a 32px font actually should be 16 px(1em) in edgeflow to display correctly??
is there a sample psd file from one of your tutorials i can download some where to speed up my learning curve?
thx
grace
4. Re: screen resolution to set up photoshop file for edge reflow
Masters and MBA May 7, 2014 6:56 AM (in response to gc234)Maybe I'm wrong, but the best option would be to work with percentages, not pixels.
You can see examples in this Adobe links:
CSS Percentage vs. Pixels - Re: How can convert the em,px,pt and % in css - CSS Width percentage layout issues - Re: DW CC Fluid grid layout how to change px width for desktop layout
sorry, I forgot this link in Adobe site: Ten things you need to know about responsive design | Adobe Developer Connection
See you,
