Crosstab - array error
Participant ,
May 07, 2014 May 07, 2014
get the following error with my code below. Please Help.
Table will be rows = dscgrd, columns = dsckcrse, rows x cols = count of dsckextid.  All grouped by teacher_anumber.
0 is not greater than zero or less than or equal to 0.
The range passed to ArraySet must begin with a number greater than zero and less than or equal to the second number.
The error occurred in C:/ColdFusion10/cfusion/wwwroot/CFIDE/groups/crosstabs.cfm: line 41
39 :           GROUP="dscgrd">  40 :  <tr><th>#dscgrd#</th>  41 : <CFSET temp = ArraySet(course_idarray, 0, b, "N/A")>
<CFQUERY NAME="crosstabquery" DATASOURCE="LIISthinkgate">
  SELECT     teacher_anumber, dsckcrse, dsckextid, dscgrd
    FROM     evaluationstudentcourse
  ORDER BY     dscgrd, dsckcrse
</CFQUERY>
<CFQUERY NAME="crosstabcolumns" DBTYPE="query">
  SELECT distinct     dsckcrse
    FROM             crosstabquery
  ORDER BY             dsckcrse
</CFQUERY>
<CFSET course_idlist = ValueList(crosstabcolumns.dsckcrse)>
<CFSET course_idheaders = ListToArray(course_idlist)>
<CFSET b = ArrayLen(course_idheaders)>
<CFSET course_idarray = ArrayNew(1)>
<table>
<CFOUTPUT QUERY="crosstabquery"
          GROUP="dscgrd">
<CFOUTPUT>
   <CFSET i = ListFind(course_idlist
                  , crosstabquery.dsckcrse)>
   <CFSET temp = ArraySet(course_idarray, i, i, crosstabquery.dsckcrse)>
</CFOUTPUT>
<CFSET rowtotal=0>
<CFLOOP index="j" FROM="1" TO="#b#">
   <td>#course_idarray#</td>
   <CFSET rowtotal=rowtotal+course_idarray>
</CFLOOP>
<td>#rowtotal#</td>
</tr>
</CFOUTPUT>
</table>
Advanced techniques
804
Participant ,
An update.
this line: <CFSET temp = ArraySet(course_idarray, 0, b, "N/A")>
Should be: <CFSET temp = ArraySet(course_idarray, 1, b, "N/A")>
May 10, 2014 May 10, 2014
I shall report that error message as a bug. It is false. It should read: "0 is not greater than zero and less than or equal to 0."
3 remarks:
  • The line <CFSET temp = ArraySet(course_idarray, 1, b, "N/A")> should be put outside the cfoutput loop. There is no need for it to run at every pass of the loop.
  • The cfoutput tag within <cfoutput query="crosstabquery"> is unnecessary.
  • The line <CFSET temp = ArraySet(course_idarray, i, i, crosstabquery.dsckcrse)> is perhaps equivalent to <CFSET course_idarray = crosstabquery.dsckcrse)>
Participant ,
May 12, 2014 May 12, 2014
Hi BKBK!
I appreciate your assistance.  What appears to have been the problem here from some research that I did is that a Cold Fusion array does not start with zero, it starts with 1.  So I changed the array to: "
<CFSET temp = ArraySet(bucketarray, 1, 2, crosstabquery.amount)>" so that the count starts with 1 and the next count is 2.
Here is my updated code, for which as you can see below the COUNT that I added is not working properly.
  SELECT distinct teacher_anumber,dsckcrse,dscgrd,  count(dsckextid) as amount
    WHERE teacher_anumber = 'A054863'
    group by teacher_anumber,dsckcrse,dscgrd
  ORDER BY teacher_anumber,dscgrd,dsckcrse
</CFQUERY>
    FROM crosstabquery
    WHERE dsckcrse = crosstabquery.dsckcrse
  ORDER BY dsckcrse
</CFQUERY>
<CFSET bucketlist = ValueList(crosstabcolumns.dsckcrse)>
<CFSET bucketheaders = ListToArray(bucketlist)>
<CFSET b = ArrayLen(bucketheaders)>
<CFSET bucketarray = ArrayNew(1)>
                  , 1, b, "N/A")>
<CFOUTPUT QUERY="crosstabquery" GROUP="teacher_anumber">
  <h4>Anumber=#teacher_anumber#</h4>
  <table border="1" cellpadding="5">
  <tr><th></th>
  <CFLOOP INDEX="i" FROM="1" TO="#b#">
    <th>#bucketheaders#</th>
  </CFLOOP>
  </tr>
  <CFOUTPUT GROUP="dsckcrse">
       <CFSET i = ListFind(bucketlist
                  , crosstabquery.dscgrd)>
      <td>#crosstabquery.amount#</td>
    </CFLOOP>
    </tr>
    </CFOUTPUT>
  </table>
</CFOUTPUT>
I got rid of the original error, however I am now not getting "0" where there should be no count. For instance 5001020 (dsckcrse), 02 (dscgrd) should have 136.  The others (01,03,04,05,KG) should be zero.  I get the following:
Anumber=A054863
500101050010205001030500104050010505001060
01120120120120120120
02136136136136136136
03145145145145145145
04163163163163163163
05165165165165165165
KG117117117117117117
Appreciate any insight you have.
Please see my first post.
Sep 20, 2016 Sep 20, 2016
Hello,
I am having a similar issue right now as well. On CF9, I am having no issues. Currently, I am testing on a new web server with CF11 update 10. The error I am receiving is similar:
0 is not greater than zero or less than or equal to 0.The range passed to ArraySet must begin with a number greater than zero and less than or equal to the second number.
Here is a snippet of my code (not sure if you will need more than that). The bolded code is where it is saying it is erroring out on and I believe is where I need to make a change. I am more or less looking for more ideas on what to check or if something has changed since CF9 that I have not read on.
<cfset bucketlist = ValueList(crosstabcolumns2.ts_desc)>
<cfset bucketheaders = ListToArray(bucketlist)>
<cfset b = ArrayLen(bucketheaders)>
<cfset bucketarray = ArrayNew(1)>
<cfset bucketTotal = ArrayNew(1)>
<cfset temp = arrayset(bucketTotal,1,b,"0")>
<cfoutput query="summedresultsNewOld" group="classcode">
  <tr><th width="225">MAIN CAMPUS</th>
     <cfloop index="i" From="1" to="#b#">
     </cfloop>
  <th width="125">TOTALS</th>
  </tr>
  <cfoutput group="ts_type" >
    <tr><th>#ts_type#</th>
   <cfset temp = arrayset(bucketarray,1,b,"0")>
   <cfoutput>
        <cfset i = listfind(bucketlist, trim(summedresultsNewOld.ts_desc))>
              <cfset temp = ArraySet(bucketarray, i, i, summedresultsNewOld.headcount)>
              <cfset temp = ArraySet(BucketTotal,i, i, (BucketTotal + summedresultsNewOld.headcount))>
   </cfoutput>
   <cfset rowtotal = 0>
   <cfloop index="j" from="1" to="#b#">
     <cfset rowtotal = #rowtotal# + #bucketarray#>
     <td width="125">#bucketarray#</td>
   </cfloop>
   <td>#rowtotal#</td>
      </tr>
  </cfoutput>
   <tr>
      <th bgcolor="##999999">TOTALS</th>
       <td bgcolor="##999999">#BucketTotal#</td>
        </cfloop>
     <td bgcolor="##999999">#ArraySum(BucketTotal)#</td>
    </tr>
  </table>
</cfoutput>
This is the result of what it should look like (currently in CF9). Any help is appreciated!
@kylec46637293
Start your own thread.
Documentation
