Import from Word with long tables
Jun 19, 2007 Jun 19, 2007
Evidently RH cannot break up tables. If a heading level (e.g., heading 4) is always contained in table cells, then it cannot be selected to create new topics during the import.
Do you have any recommendation for this other than change the original word document and manually cut the tables at the required spots?
416
Guest
Is the heading 4 tag only in the cells where you want the table to break? Is only the one cell populated in each of those rows?
Brian
Guest
Jun 20, 2007 Jun 20, 2007
If your table is similar to this:
Columns 3-x
Row 1, cell1 header text
Row 2, all columns with data
Row 3 etc as row 2
Row 12 (example) 2nd header text
and so on, the following macro will find each header, select the row, convert tabe to text, re-apply the heading level.
You can specify the heading level you want.
Sub SplitTable()
Selection.Find.ClearFormatting
Selection.Find.Style = ActiveDocument.Styles("Heading 4")
With Selection.Find
Do While Selection.Find.Execute
Selection.SelectRow
Selection.Rows.ConvertToText Separator:=wdSeparateByTabs, NestedTables:=True
'Change the heading level here to what you require
Selection.Style = ActiveDocument.Styles("Heading 4")
Loop
End With
End Sub
Place the macro in your template .dot file.
Open the document and run the macro.
Hope this helps,
Brian
PS. If you are not sure about installing the macro, see this article.
Guest
Jul 03, 2007 Jul 03, 2007
Thanks for your help and please excuse the late reply. I had to suscribe with a new login now because my old account somehow vanished..
RoboHelp Documentation
Download Adobe RoboHelp
