Coldfusion 10 problem with cfhttp postype xml
May 09, 2014 May 09, 2014
We are making a cfhttp call.
We are submitting xml data. We are able to send information from server A to server B, but server B is not giving us any response.
Our code works for coldfusion 8 and 9 but it does not work for coldfusionh 10.
This is the snippet of the code
<cfhttp method="post" url="#httpURL#" timeout="3000" useragent="#CGI.http_user_agent#" >
    <cfhttpparam type="XML" value="#xmlRequest#" name="CLRCMRC_XML" >
</cfhttp>
The contents from server B can be access by
<cfdump var="#cfhttp.FileContent#">.
Note This works in coldfusion 8 and 9 but we are not getting any data from server B using coldfusion 10
812
Community Beginner , May 13, 2014 May 13, 2014
Issue solved.
It was a  matter of changing this line
<REQUEST KEY="#companykey#" PROTOCOL="0" FMT="1" ENCODING="0">
to use PROTOCOL="1"
May 11, 2014 May 11, 2014
Could you show us the structure of the URL and how you create the variable xmlRequest?
Assuming server B is also on ColdFusion, is it using getHttpRequestData().content to access the XML contents?
May 12, 2014 May 12, 2014
The url is an https call
Below is the xml data being sent to the other server.
<cfxml variable = "xmlRequest">
    <cfoutput><REQUEST KEY="#companykey#" PROTOCOL="0" FMT="1" ENCODING="0">
        <TRANSACTION>
            <FIELDS>
                <TERMINAL_ID>#terminalID#</TERMINAL_ID>
                <SERVICE_FORMAT>1010</SERVICE_FORMAT>                            <!--- 1010 = Card not present (E-commerce) --->
                <CURRENCY_CODE>124</CURRENCY_CODE>                                 <!--- 124 = Canadian currency code, 840 = us code --->
                <CURRENCY_INDICATOR>0</CURRENCY_INDICATOR>                        <!--- 0 = currency will be processed as a domestic currency transaction --->
                <TRANSACTION_INDICATOR>7</TRANSACTION_INDICATOR>                <!--- 7 = account information was received through a secure internet site --->
                <SERVICE>CC</SERVICE>                                            <!--- CC = Credit Card Transaction--->
                <SERVICE_TYPE>DEBIT</SERVICE_TYPE>                                <!--- DEBIT = CHARGE CC ACCOUNT HOLDER--->
                <SERVICE_SUBTYPE>SALE</SERVICE_SUBTYPE>                            <!--- Authorize and move funds from account holder to merchant--->
                <GOODS_INDICATOR>P</GOODS_INDICATOR>                            <!--- P = physical goods, as opposed to electronic goods --->
                <PIN></PIN>
                <OPERATOR>Amazingclu</OPERATOR>                                 <!--- operator/location responsible for the transaction generation, in this case, the website--->
                <AMOUNT>8</AMOUNT>
                <ENTRY_MODE>3</ENTRY_MODE>                                        <!--- 3 = data was manually entered, no card/check present --->
                <CVV></CVV>
                <EXPIRATION></EXPIRATION>
                <ACCOUNT_NUMBER></ACCOUNT_NUMBER>
                <FIRST_NAME></FIRST_NAME>
                <LAST_NAME></LAST_NAME>
                <ADDRESS></ADDRESS>
                <CITY></CITY>
                <STATE></STATE>
                <POSTAL_CODE></POSTAL_CODE>
                <PHONE></PHONE>
                <COUNTRY></COUNTRY>
                <USER_DATA_0></USER_DATA_0>                                        <!--- optional field allowing us to send arbitrary transaction data --->
            <!---    <VERBOSE_RESPONSE>1</VERBOSE_RESPONSE>                         for testing purposes only --->
            </FIELDS>
        </TRANSACTION>
    </REQUEST></cfoutput>
</cfxml>
I used your XML to run the following test. The test page uses cfhttp to post the XML to a CFC. It works as expected, returning the XML.
testPage.cfm
<cfset companykey="myKey123">
<cfset terminalID="ID123">
        <TRANSACTION>
            <FIELDS>
                <PIN></PIN>
                <AMOUNT>8</AMOUNT>
                <CVV></CVV>
                <ADDRESS></ADDRESS>
                <CITY></CITY>
                <STATE></STATE>
                <PHONE></PHONE>
                <COUNTRY></COUNTRY>
            </FIELDS>
        </TRANSACTION>
</cfxml>
<cfhttp url="http://127.0.0.1:8500/workspace/cfhttpTest/MyApp.cfc?method=echoXml" method="post">
<cfhttpparam type="xml" value="#xmlRequest#">
</cfhttp>
MyApp.cfc
component {
remote string  function echoXml()
     // the request data
    var xmlDoc = getHttpRequestData().content;
    return toString(xmlDoc);
I solved the issue. The issue had something to do with a setting that returned via tcp/ip and not http.
Issue solved.
to use PROTOCOL="1"
May 14, 2014 May 14, 2014
Glad to hear you solved it. Please mark the correct answer, as it will help someone else.
Documentation
