9 Replies Latest reply on Jun 19, 2007 4:20 PM by Newsgroup_User
    Layout tables
    smealing Level 1
      Hello All.
      A quick question for a DW novice; how do I get rid of the borders round layout tables and cells which are visible in the browser preview? Easiest way to see my problem is to simply draw a single layoout table in a blank page and then preview in a browser, all that can be seen is a dark outlin around the layout table.
      I cannot find how to do this in the help menu.
      Any suggestions would be much appreciated
      Regards
      Stuart Mealing
        • 1. Re: Layout tables
          smealing Level 1
          I just read a similar post where the solution suggested was to set border = "0" in code view for each layout table and/or cell. This appears to do the trick. Is there any reason why it is not possible to do this in the property inspector?
          Regards
          • 2. Re: Layout tables
            Level 7
            Are you using the latest version of DW (DWCS3)? If so, it's because setting
            it via the property inspector would use decrepated code and DW is trying you
            push you into using valid html and css instead :-)
            Nadia
            Adobe® Community Expert : Dreamweaver
            CSS Templates |Tutorials |SEO Articles
            http://www.DreamweaverResources.com
            ~ Customisation Service Available ~
            http://www.csstemplates.com.au
            "smealing" <webforumsuser@macromedia.com> wrote in message
            news:f58l70$ibq$1@forums.macromedia.com...
            >"0"
            > trick.
            > inspector?
            > Regards
            • 3. Re: Layout tables
              bregent Most Valuable Participant
              >DW is trying you push you into using valid html and css instead :-)
              Too bad it doesn't push new users away from layout tables :)
              • 4. Re: Layout tables
                Level 7
                "bregent" <webforumsuser@macromedia.com> wrote in message
                news:f58p7v$n6o$1@forums.macromedia.com...
                LOL - I totally agree with you !
                That would certainly be a 'push' in the right direction :-)
                Nadia
                • 5. Re: Layout tables
                  Level 7
                  ": Nadia : ** Adobe Community Expert **"
                  <nadia@REMOVEdreamweaverresources.com> wrote in message
                  news:f58lgr$iom$1@forums.macromedia.com...
                  > ...decrepated code ...
                  And there's nothing worse that decrepated code! :-D
                  Patty Ayers | Adobe Community Expert
                  www.WebDevBiz.com
                  Free Articles on the Business of Web Development
                  Web Design Contract, Estimate Request Form, Estimate Worksheet
                  • 6. Re: Layout tables
                    Level 7
                    I can think of one or two things worse....
                    Murray --- ICQ 71997575
                    (If you *MUST* email me, don't LAUGH when you do so!)
                    http://www.dreamweavermx-templates.com - Template Triage!
                    http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                    http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                    http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
                    "P@tty Ayers ~ACE" <pattyayersTAKETHISOUT@REMOVEgmail.com> wrote in message
                    news:f597p7$bgj$1@forums.macromedia.com...
                    > www.WebDevBiz.com
                    • 7. Re: Layout tables
                      Level 7
                      Depreciated code?
                      Regards
                      John Waller
                      • 8. Re: Layout tables
                        Level 7
                        You've obviously never seen badly decrepated code after it's been sitting
                        for a couple of days..
                        www.WebDevBiz.com
                        "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                        news:f5990d$csd$1@forums.macromedia.com...
                        > message news:f597p7$bgj$1@forums.macromedia.com...
                        >> www.WebDevBiz.com
                        • 9. Re: Layout tables
                          Level 7
                          On Tue, 19 Jun 2007 14:37:21 -0400, "P@tty Ayers ~ACE"
                          Well, sometimes that defecated code that I pull out of my ... well ...
                          never mind.
                          Gary
