1. Re: Audition CS6 crashes while running Adaptive Noise Reduction
SteveG(AudioMasters) May 9, 2014 3:47 AM (in response to Srivas 108)Srivas 108 wrote:
What to do?
There will be a crash report, even though you didn't see it. Probably the first thing you should do is to read the FAQ about crashes, and take it from there.
2. Re: Audition CS6 crashes while running Adaptive Noise Reduction
Srivas 108 May 9, 2014 5:14 AM (in response to SteveG(AudioMasters))Thank you Steve, but the problem is that not only Audition crashes, but the whole system shuts down. How then can I monitor the crash?
3. Re: Audition CS6 crashes while running Adaptive Noise Reduction
SteveG(AudioMasters) May 9, 2014 7:29 AM (in response to Srivas 108)Assuming that it's Audition that crashes first, the log file will have been written. If the OS crashes first, then you have something more serious wrong with your system anyway. The fact that you've done a system reinstall points to something else going on... especially as Audition didn't crash before. What OS are we talking about?
4. Re: Audition CS6 crashes while running Adaptive Noise Reduction
Srivas 108 May 9, 2014 8:16 PM (in response to SteveG(AudioMasters))Yes, I think now that this is not directly Audition related since the system also crashed when Audition was not running. Something is definitely wrong with the system. The system is Win 7 64 Home Edition. It was working ok before. Maybe I should install all the updated? I hate to do that, my experience is that it slows down the system in the long run, but looks like I should do that.
5. Re: Audition CS6 crashes while running Adaptive Noise Reduction
SteveG(AudioMasters) May 10, 2014 2:39 AM (in response to Srivas 108)Srivas 108 wrote:
I run the pro version, but it's basically the same. I've got all the updates installed, but I haven't noticed it slow down at all. Mind you, this is a fast system anyway. But if it's crashing, then installing updates won't fix that; you need a fresh reinstall on an absolutely clean disc first. Okay, that's a pain - but look on the bright side; you aren't running Windows 8. Recently I wasted nearly a day of my life on that, and I'll never get it back. The basic rule about M$ OS's hasn't changed - it's only the odd-numbered ones that are worth bothering with, as a rule. And none of them are worth installing until the first service pack is issued.
6. Re: Audition CS6 crashes while running Adaptive Noise Reduction
Srivas 108 May 10, 2014 5:08 AM (in response to SteveG(AudioMasters))Ok I'll do that. I guess something went wrong. Thanks Steve.
7. Re: Audition CS6 crashes while running Adaptive Noise Reduction
Srivas 108 May 12, 2014 5:41 AM (in response to Srivas 108)I found the solution! I had to revert my graphics driver to the one recommended on the site of the computers manufacturer. Last version of Nvidia wasn't actually good. Now everything seems to work ok.
