1 Reply Latest reply: May 10, 2014 4:00 AM by c.pfaffenbichler RSS
    Combine 2 specific images, automatically
    kaiserlumine
      I work on PS CS4
      I need to combine 2 images images into one (Both are in the same folder):
      (The process must be applied to 2 sets of images)
      set 1) A000.png / A001.png (Bottom layer, no changes)
      set 2) B000.png / B002.png (Top layer, no changes)
      I modified a script i found on this page:
      combine three images into one but...
      But i got error in the line 28 (Error 1233: Expected a reference to an existing File/Folder )
      What i'm doing wrong?
      Is there an easier way to combine two images?
      Here is the script:
      #target photoshop
      var myDoc = app.activeDocument;
      var projectName = app.activeDocument.name;
      var projectPath = app.activeDocument.path;
      var originalRulerUnits = app.preferences.rulerUnits;
      app.preferences.rulerUnits = Units.PIXELS;
      var num = 0;
      var finished = 0;
      for (i=97;i<=122;i++) {
          var letter = String.fromCharCode(i);
          var letter2 = letter.toUpperCase();
          for (e=0;e<=100;e++) {
              e = e;
              numberCheck();
              var targetName = letter2 + num + ".png";
              if (targetName == projectName) {
                  e = e + 1;
                  num = e;
                  numberCheck();
                  var projectPath1 = new File(projectPath + "/" + targetName); //Change the "/" if your 50% opacity layer's file is in a sub-folder (ie: change "/" to "/50Opacity/")
                  var myDoc1 = app.open(projectPath1);
                      app.activeDocument = myDoc1;
                      var newLayer = myDoc1.layers.getByName("Background")
                      var copiedLayer = newLayer.duplicate(myDoc, ElementPlacement.PLACEATBEGINNING);
                      app.activeDocument = myDoc;
                      copiedLayer.name = "Layer 1";
                  finished = 1;
                      myDoc1.close(SaveOptions.DONOTSAVECHANGES);
              if (finished == 1) { break; }
      function numberCheck() {
          if (num >= 100) { num = e; }
          if (num >= 10 && num <= 99) { num = "0" + e; }
          if (num <= 9) { num = "00" + e; }
      app.rulerUnits = originalRulerUnits;
