Hi Angela. I'm currently looking into this too. Check out
Peter Grainge's site - click
here
for an article listing four methods of calling webhelp. Webhelp Pro
is essestially the same thing so you can follow the same rules. As
far as the developers are concerned, they need to change every
instance where the help is called (e.g. Help menu item, F1 from a
dialog). The syntax of the call is dependent on which method you
choose from Peter's article but your developers should be able to
work that out for you.
